New! Dark mode!
(Topic ID: 208558)
Hollywood heat weird things are happening
By louknees
2 years ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by Topher5000
#1 2 years ago
Hello. I just picked up a Hollywood heat and when I was playing it at the persons house it played fine other than 1 of the 1 amp slo blow fuses needed to be replaced because it was dead. We tested this by moving it from the different places that use the 1 amp slo blows (the out hole, the ball kicker, the left and right target banks). The game played fine. When I got it home and set it up I replaced the 1 amp slow blow with a working one and booted up the game. The game booted fine but I couldn't start a game. I also couldn't get it to test mode. I shut it off reseated the connectors and then when I turned it on the display wasn't working. Then I tested the fuses and turned it back on and the game looked like it was going to work, the display came on it scrolled through the 1st and 2nd score and then froze. Still not able to start a game. Still no test mode. I reseated the connectors again and when I turned it on test mode was on the display but I couldn't step through it. I turned it off again checked the fuses again turned it back on and got boxes on the display. Also different playfield lights would be lit each time or the 3 bottom ones would be and then one would go out and then another. I even tried a different outlet in a different room thinking it was a power issue. I don't know what to do next and wonder what happened during the move. Any help with this would be greatly appreciated and thank you for taking the time to read this
#2 2 years ago
The F10 fuse keeps blowing. That's the problem. Where do I go from here? Any help with this would be super greatly appreciated.
#3 2 years ago
Is that a green ramp?where did you get it?
#4 2 years ago
forceflow told me that the MPU only needs 5v & the slam tilt to boot. With the machine off, try disconnecting J4 & see if it boots. You can also disconnect J5 or J6, but I don't know which has the slam tilt connected. You could check wire colours for that.
Disclaimer: I'm quite the noob & I'm going off my Raven manual, so hopefully someone who knows what they're doing can help.
#5 2 years ago
Quoted from Topher5000:
I'll give it a shot. Thanks. Right now the machine boots up differently each time.
Some times the outhole solenoid will fire and stay engaged, other times it will fire properly other times the knocker fires. The display shows a variety of things, the random times it wants to show anything at all. Different lights on the playfield are illuminated and then some will go out while the game is on.
#6 2 years ago
Quoted from pinostalgia:
It's actually a custom re-theme of a Hollywood Heat. It's Return of the living dead. A few pictures attached. The ramp was just painted.
#8 2 years ago
Do you have a multimeter? I'd start by checking voltages at the power supply board. There should be test points on the board you can use to test the various voltages. Test them all, jot them down, and post them here. Without good voltages, you could wind up chasing your tail trying to get to the bottom of this...
#9 2 years ago
Quoted from frunch:
I will do that. Also, this is my first system 80b and I heard gottlieb was notorious for grounding issues and there's an upgrade that you can get to help with the grounding issues. It's like a wire that connects to the CPU. Does anyone know exactly what that is? Thanks again for your help in all of this.
#10 2 years ago
Pinwiki has a section on them http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_80#Ground_updates
As I understand it, the ones on the transformer panel are the most important & if you ground each board, the one between the MPU & driver board is redundant. I did it anyways using the -072 molex pins.
$ 12.50
Gweem's Mods
$ 52.00
$ 299.00
Displays
Boston Pinball Company
$ 6.50
$ 12.00
Tools
Troxel Repair
$ 175.00
Professor Pinball
$ 5,899.00
Classic Game Rooms
Great American Pinball
Various Novelties
GC Pinball
$ 11.00
The MOD Couple
$ 18.00
Pin Monk
$ 18.95
$ 48.00
$ 123.00
$ 12.00
Third Coast Pinball
$ 40.00
$ 8.00
Docent Electronics
$ 339.00
