(Topic ID: 189811)
Hollywood Heat flipper rebuild question
By Ericc123
6 years ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by Ericc123
#1 6 years ago
I offered to help my friend rebuild the flippers for his Hollywood Heat pinball machine. I helped him find the rebuild kit online but encountered an unexpected problem when tearing the old ones apart. I can't figure out how to get the piston out from this metal bracket. The kit came with a new piston obviously, but I need to keep this metal bracket intact. The two of us couldn't figure out how to pry it apart. There is a pin going though the middle holding the piston in place, but I can't seem to pry it out. It won't push through either side. I saw another gold pin which you can see in the picture that turned with an allen wrench, but it also won't come out. Any help would be greatly appreciated.
Thanks in advance,
Eric
#2 6 years ago
It is a roll pin. A roll pin punch works great. I use a short length of 2X4 with a small hole through it ( so you don't nail the roll pin into the 2X4 ) then hold the object over the hole. Set a roll pin punch on the roll pin, and whack away with a hammer.
Reverse the procedure to secure the new plunger.
#3 6 years ago
Thanks LTG I appreciate the help. I googled a roll pin punch and I think I know what I need to do. Put the small thin part of the punch in the hold and hammer it through.
#4 6 years ago
Quoted from Ericc123:
If you use a regular punch, careful you don't get it stuck in there.
A roll pin punch has a rim that fits over the edge of the roll pin, and a small extrusion ( half round ) that sits in the hole in the roll pin.
#5 6 years ago
Ok, hopefully my last dumb question of the day. Am I knocking out the gold pin or the metal one in between the plunger? I'm not even sure if the silver one is a pin or if it's part of the bracket.
#6 6 years ago
These aren't dumb questions. All great stuff to ask BEFORE you take a punch and a hammer to that pin.
#7 6 years ago
Quoted from boscokid:
Especially when it's not mine.
#8 6 years ago
remove roll pin
f9f2634744d1d21be75a9b9cec25e1ea97587597 (resized).jpgf9f2634744d1d21be75a9b9cec25e1ea97587597 (resized).jpg
#9 6 years ago
oldschoolbob pointed it out.
See the oblong hole in the new one ? See where the old one pivots ? Knock the gold rivet out and you don't accomplish swapping old plunger with new.
#10 6 years ago
Oldschoolbob, it's embarrassing that I need a diagram but that's actually perfect for me so thank you very much. LTG you are the best as always.
$ 1.00
Pinball Alley
$ 83.00
PinballReplacementParts
1,995
Riverside, CA
This page was printed from https://pinside.com/pinball/forum/topic/hollywood-heat-flipper-rebuild-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
