Hi all
I'm trying to fix up a Hollywood Heat. Gottleib System 80B
I got everything working except for the 2 flashers located at L15. They are both out and cant figure out why. All other flashers that are there work perfectly fine.
What are some tests I can run to check why this isn't working? Is this something on the AUX lamp driver board? The solder joints to the lamp sockets all look good
Any details instructions you can suggest on how to test what is wrong would be greatly appreciated. This is the only issue left to solve and it is complete.
Thank you for the help in advance
