Hello everyone,
I have a 80B Hollywood Heat machine that instantly burns out the fuse to the popbumper. I have tried a number of fuses, replaced the pop bumper driver board, and beeped out all the grounds. My machine has the grounding mod (wirenut all the ground wires to the transformer case). I even verified the coil was good by directly powering it via a DC power source (it pops in that case) and checking the resistance (it was a nominal 4.5 ohms)
I feel like I have tried everything.
The popbumper semantic shows two grounds across it. (see attached image) Pin 6 and Pin 2 should effectively be the same ground, however when using each one as a reference I get a ~.25 volt discrepancy when reading to pin 5. Could this be causing the issue? Should I just short these two grounds together? Why would the "DC Ground" and the "Solenoid Ground Bus" be at a different potential, and why even have two different grounds in this case?
Please advise.
