New! Dark mode!
(Topic ID: 277305)
Hokus Pokus Refresh Tips and Questions
By RadMax8
80 days ago
  • 21 posts
  • 10 Pinsiders participating
  • Latest reply 2 days ago by shadow2525
There have been 17 images uploaded to this topic. (View topic image gallery).
#1 80 days ago
Hey guys,
My grandparents have had a Hokus Pokus living in their basement since at least the early 90’s. I’ve played what seems like thousands of games on it. It was always in pretty decent shape, but it never, ever had any love shown to it, no cleaning or maintenance or anything. In the last 10 years since I moved further away, I don’t think the machine has been played much at all. My grandparents have opted to move to a condo, and as a result I now have the machine! I’m super excited, however a cursory look has shown the machine is much rougher than I remember. I know some of the standard things to do, but I need a bit of help and advice.
New Rubber- Any kits better than others?
Playfield Posts- Many of them have broken. What size are these on this particular machine? I can’t seem to find those details.
New Plunger Springs- These seem pretty standard across all EM Machines...
Playfield Cleaning- I’ve seen people use alcohol and Mr. Clean magic erasers, specialized cleaners, and soap and water. What’s a good place to start? Does it make sense to wax the playfield?
Lubrication and Cleaning of Mechanical Parts- What should I be looking for to lube and clean, and what are some good products to use?
Locks- Had to drill the back box lock out, but I’d like to avoid that on the coin door... can I really pick it with a nail clipper file? I believe the locks are 7/8”.
Currently none of the playfield lights are illuminated, but I’m pretty sure all the functionality of the targets, roll overs, and spinners work. I think it may be a fuse, but I can’t get into the box just yet (see lock comment).
Any advice or experience you guys can share would be amazing. I’m looking forward to learning how to get this machine restored and playing great for a long time coming, and also learning yet another new hobby.
Thanks, all!
#2 80 days ago
Welcome to Pinside!
You will find many useful tips here: http://www.pinrepair.com/em/index.htm
For parts, rubber kits and help with what parts you need contact: PBR - The Pinball Resource
http://www.pbresource.com/
For your first order, call. Steve will set up your account and explain how you pay.
Marco Specialities is another source for parts: https://www.marcospecialties.com/
For post replacements, you may want to check eBay or the “EM parts wanted” thread here on Pinside.
When you replace the rubber, do not double up the slingshots.
Lastly, it’s not a hobby, it’s a disease!
#3 80 days ago
Just drill the lock if you don't have the key. Either put a new keyed lock in or a thumb lock.
Be careful cleaning the playfield as the reds will fade fast if you scrub too hard. I start with a simple wipe down with a blue shop paper towel sprayed with simple green. Everyone has their own technique. Do not wax the playfield until you're certain it is clean or you just seal in the dirt and grime.
The reproduction post that are supposed to be for these older machines have an odd blue hue to them. Also documented on pinside.
Some just change over to the new red post or clear if you want to light em up.
And http://www.pbresource.com/ is the place to become a customer.
-Mike
#4 79 days ago
Hey, thanks for the tips, guys. I will give Steve a call and get some parts on order. I’m really looking forward to rejuvenating this machine!
#5 79 days ago
There are many posts on cleaning the playfield. Do not start with alcohol and a magic eraser. That is a last resort and ends with you needing to clear coat the playfield. My procedure is to start with naphtha and then move up to novus 2 if needed. You can always go stronger and you can’t go back if you mess up.
I have refurbished 2 of those games. They are a lot of fun. You can definitely get new plastic posts. The vendors have pictures so that you can match them up. I recommend drawing a map of the short and tall ones and which screws are machine thread, wood screws, and long/short when you start pulling apart the playfield.
Good luck,
Dave
#6 79 days ago
radmax8
Looks like you are in the Cleveland area. I am in Westlake and also have a Hokus Pokus. Let me know if you have any questions and I can go check out my game (for visuals) or refer to my schematic. Once you get the door cabinet door lock taken off let me know if you have a schematic.
#7 76 days ago
That’s true pinside fellowship there! I too live close by. Hit either of us up for any help needed. The peeps here are such a tremendous help and resource. Welcome!
#8 76 days ago
Quoted from terrapinmark:
radmax8
Quoted from Nikrox2:
Hey guys, nice to see a couple Clevelanders here!
So I drilled the lock (and broke 3 bits in the process... embarrassing!) and inside it was incredibly clean for a 45 years old machine. Luckily there was an envelope with the manual and a full set of schematics... Thanks, Clarko!
I also found the culprit for the playfield lights, a blown fuse. However, the fuse holder is not long for this world. As you can see, it’s already had one replaced. I’ve ordered a whole new fuse holder to put that worry to bed. Play counter shows 25,065, which means about 470 plays a year. That said, it might not have had 470 plays in the last 15 years, so it’s definitely not a museum piece! I figure I’m probably directly responsible for 1500-2000 of those plays as a kid. It’s a fun machine!
I’ve got all the basic parts on order to at least get the thing running like it should. All new posts, new rubber, new bulbs, new ball, new springs. I’m hoping those will arrive this weekend so I can “pop the hood” and get this thing going.
AEF83C27-AA50-4229-BCDD-C668C9060989 (resized).jpegA829C62D-375E-4FB9-B84A-CABEF279E9D5 (resized).jpegC3DD5A88-E4E6-45E6-A348-0BB387DC684E (resized).jpeg12170B5C-D3DC-4923-AF87-35192A7028BB (resized).jpeg00E9E454-6260-4C7F-85D5-689F225C4321 (resized).jpeg13580B22-F18B-449D-BBA7-88244E4A9A41 (resized).jpeg1FA4F786-5852-4D38-BE3C-EC4D5782F7FD (resized).jpeg45CE279A-06EE-4C18-B282-1C01842B59AC (resized).jpeg
#9 75 days ago
That is awesome to see such a clean specimen. You’re lucky to have all the original docs. I’m very jealous
Good luck with the refurb, you’re gonna have a great game!
Dave
#10 75 days ago
Quoted from dgAmpGuy:
Dave.......agreed. That is a very nice example and will clean up very nicely.
#11 74 days ago
Hey guys,
I'm fairly new at all of this. I just picked up a Hokus Pokus project machine couple weeks ago. I may or may not be in over my head. Can either of you tell me where your Knocker unit is mounted? I think my machine's is AWOL. Also, I love this cabinet art and i plan on doing the stencil thing as the cabinet has been repainted white. (clean slate at least). Is the original paint a solid white or off-white? with or without that speckled effect?
Any info is much appreciated.
- Tom G.
#12 74 days ago
This is what I used on mine. Not to happy with it my choises. Generally just to dark. Just my opinion. The base coat was ok.
16005229175532666597725136229116 (resized).jpg16005233385843087376069432840250 (resized).jpg16005230010778692980719481031433 (resized).jpg
#13 74 days ago
I think you did a great job on that paint job. I get that you want to match the colors exactly, but that paint job still really looks great. Thanks again for those photos. Those two little screw holes in the back box looked suspicious. lol. And seeing those spacers underneath the knocker solve another mystery. That's a big help.
- Tom G.
#14 73 days ago
Quoted from Thogar480:
- Tom G.
#15 73 days ago
Grab yourself a flipper rebuild kit. I'm not sure what the Bally's are going for maybe $50 tops. It's well worth it.
Coil sleeves in your pop bumper would be nice too. Cheap to do. Maybe grab some pop bumper yokes (metal) as you may find one broken when you take it apart. This is also cheap to do and improves play.
Enjoy the game. I've owned 2 before and will eventually own a 3rd and never sell next time.
#16 56 days ago
Hello all,
I have another favor to ask. Could someone take a photo of the relay bank in the back box. Mine is missing the label - this would save me a lot of headaches. Hope everyone is doing well. Thanks
- Tom G
9B380075-3474-4C98-B716-4E8636D876B8 (resized).jpegB736BE0E-766C-49EB-9384-66052DAE5409 (resized).jpeg
#17 56 days ago
#18 55 days ago
Major thanks !!
1 month later
#19 3 days ago
hi all,
just wondering if anyone can help? l got a Hokus Pokus pinball machine, played it for around 3 times and it stopped... but l had a look and the 50v 10a fuse was blown... which l replaced but now when you turn it on all the lights come on and when you press the start button it starts to reset and then blows the fuse again..
any ideas? and the what is the 50v 10a fuse for? it's the one in the fifth picture...
thanks..
#20 3 days ago
That fuse protects the voltage that goes to every coil and relay in the game.
The fact that it is blowing means that there is a short circuit between the two wires the carry 50v through the machine. It could be that there is a burned up coil or it could be a short circuit between two wires or even solder tabs on the switches. Even a stray screw or piece of metal could fall into the wrong place. It’s tough to tell.
The easiest thing to look for is a burned up coil. Sometimes they make it obvious.
After that, I’d begin with trying to determine exactly how far through the startup process you’re getting, and then use the schematic to trace what coils and relays are active at that point.
You can make or buy a circuit breaker that clips into the fuse holder to avoid going through a bunch of fuses. Alternatively, you could make what is called a “dim bulb tester”. It is commonly used when testing old electrical equipment to prevent excessive current from damaging what you’re working on. I use on in my amp repair work and have used it to solve a couple of fuse blowing pinball machines. When your game gets to the point where the fuse is going to blow, the bulb will go bright and the relay will start chattering. Then you know that you are close to the problem and you haven’t fixed it yet (but it prevents the fuse from blowing).
Good luck,
Dave
#21 2 days ago
thanks for that Dave, l'll give it a whirl ...
€ 59.80
Lighting - Backbox
Freddys Pinball Paradise
Cabinet Parts
Troxel Repair
$ 1,400.00
$ 40.00
Metal-Mods
$ 95.00
pinballmod
$ 99.00
Arcade Upkeep
$ 9.95
$ 18.99
$ 109.00
Cabinet Parts
Tilted Pinball
Various Novelties
GC Pinball
$ 999.00
$ 200.00
Professor Pinball
$ 749.00
COINTAKER.COM
CzTV Mods
$ 125.00
Sparky Pinball
$ 9.99
Tools
PinShield
$ 229.99
$ 14.95
$ 239.00
Tilttopper
$ 54.99
$ 229.99
£ 20.00
Apparel - Women
Pinball Wheezer
Apparel - Unisex
Project Pinball Charity
