Scoring works properly until the score reaches 92,000. At that point the Over The Top lights and buzzes, and no further 1000 point increments will score, and the coil for that reel stays energized.
Possibly a score reel switch adjustment. Looking for switch settings for this.
Just found a Williams manual that show the following settings. Are these the same for a Bally? Not sure why the scoring would stop at 92,000 and sound the "Over the Top" buzzer.(On player 1 only)
0 Position=All open, 1-8 Position=2 top switches closed, bottom open, 9 Position=All closed.
You'll need to find the switches that send power to the over the top delay relay. I'm looking on a schematic for Aladdin's Castle, so they should be similar. Check the following switches:
1st player 10000-90000 unit 9th position switch
2nd player 10000-90000 unit 9th position switch
1st player 10000-90000 unit EOS switch
2nd player 10000-90000 unit EOS switch
Over the top delay relay switch (switch with an orange wire and yellow/brown wire???)
Check for any shorts in the these switches. Look for any wires or wire lugs that are touching. Check the adjustment of the switches...
Also, make sure there is a working #455 lamp in the lamp socket of the over the top delay relay...
This page was printed from https://pinside.com/pinball/forum/topic/hokus-pokus-over-the-top-scoring and we tried optimising it for printing. Some page elements may have been deliberately hidden.
