(Topic ID: 202281)
Hobbit Popup issue since 2.0
By jrawlinson_2000
2 years ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by jeffspinballpalace
#1 2 years ago
Hi all, just wondering if other v2.0 Hobbit owners are getting this.
I have a strange issue since upgraded to Hobbit v2.0, what is happening is;
The spider beast (lower left) mech is staying up too long when the ball is in the kick-back as such it hits the side of the mech when launched back into the playfield.
Conversely to that the Goblin beast (upper left) mech is staying up not long enough to hit it, what happens is the ball goes over the roll-over so the Goblin pops up and just as I hit the ball with the flipper it pops back down before I can hit it!
Annoying or what.
Anyone else getting this?
I'm sure all was fine with the previous version of the code.
#2 2 years ago
My wife and I have been running 2.0 for a while and our game does not behave this way.
#3 2 years ago
If you power the game down and manually push the spider up from underneath the playfield does it fall instantly or does it hang? It almost sounds like the mech is rubbing or binding which is mechanical.
As far as the goblin, go into the test, full menu, test, device test, beast pop up. Select the goblin and see if when he is activated if the actual creature switch is already active. You might need to adjust this switch manually.
I think the upgrade to 2.0 and this issue are just coincidental.
Let me know what you find.
#4 2 years ago
I've been on 2.0 for a while and have not had this happen either.
#5 2 years ago
Quoted from KingPinGames:
Thanks for the assistance.
Upon investigation I indeed found the Goblin switch to be too sensitive, so I enlarged the gap, I also noticed that when the beasts pop up they sway as such have been triggering.
I also found that if I pushed the mechs up by hand the Spider mech was not as smooth at dropping as the other three beasts, I could not really see a where it was catching.
I therefore detached the plunger to at least isolate the mech or the plunger runing through the coil plastic, both appeared fine, so I reassembled only to find the mech would no longer go up by hand.
In the end it appeared that the nut that kept the plunger attached to the mech needed to be a tad looser, then the mech worked and runs as it should do, it must have tightened over time.
Anyway all working now so thanks for assistance all.
#6 2 years ago
Quoted from jrawlinson_2000:
glad to hear it. now go enjoy your game!
#7 2 years ago
Nobody can play if the nuts are too tight.
In the end it appeared that the nut that kept the plunger attached to the mech needed to be a tad looser, then the mech worked and runs as it should do, it must have tightened over time..../blockquote>
$ 88.00
$ 49.95
Pin Stadium Pinball LEDs
6,800 (OBO)
Portage, IN
$ 62.00
The MOD Couple
