I still have a recurring problem with my Goblin Pop-up. I've previously posted it on this thread (p. 55), but the problem persists. After several hits, the Goblin head stops popping up. The LED lights up, but the steel flap only moves upward above the PF surface about 1/16". I then stop game play & manually pop him up & twist head slightly. It then pops up for only a few additional hits & then quits working.
With the PF raised on skids and manual movement, there is absolutely no obstruction or impingement of the mechanism. It moves freely without hitting the PF wood edge. The Goblin head does not hit the plastic insert. I even removed the insert to make sure.
With the PF down & in the test mode, the Goblin steel flap only moves upwards 1/16"' to 1/8" above the PF surface, even after twisting the head ever so slightly. The other Pop-ups (Orc, Warg & Spider) work fine. In their test modes, the the steel flaps move about 1/2" above the PF & their mechanisms make a loader noise.
With the PF raised against the back box & in the test mode, the Goblin mechanism slides up to the steel flap & stops. With the other pop-ups, their mechanisms slide up to & hit the steel flaps and, as stated previously, make a loader noise. It's as if the Goblin coil is not strong enough/defective.
Any thoughts? I really think it might be a defective coil/sleeve. I really don't know why the slight head twist allows the mechanism to work a couple of times, since there is absolutely no obstruction or impingement to movement.
I emailed Victor 3+ wks. ago and he has yet to respond.
If it is the coil, how do you switch it out for a new one? I ordered a coil from the Hobbit Parts Store for $35 plus $28 two-day shipping. To switch coils, I assume you have to remove the two flap compression springs, lift off the steel flap, unplug the respective Molex connectors, & unscrew the 4 anchoring screws of the mechanism & pull entire mechanism out.
Thanks for any replies.
