(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
  • 7,892 posts
  • 518 Pinsiders participating
  • Latest reply 12 hours ago by Mr_Outlane
  • Topic is favorited by 192 Pinsiders
There have been 1,152 images uploaded to this topic. (View topic image gallery).
16 key posts have been marked in this topic (Show topic index)
There are 7892 posts in this topic. You are on page 63 of 158.
#3101 2 years ago
Quoted from yonizzell:
Good call. If the playfield protector affects anything as far as gameplay it's very minimal and you'll be grateful you added it if you ever decide to sell the machine ( there will be a like-new playfield underneath it!).
Are you sure its not the reason your selling it? You say game hasnt clicked with you maybe its the playfield protector effecting the gameplay for you? Ive never knowingly played a game with playfield protector so i dont know how much they effect gameplay. Did you play one at a show that you really liked then bought one with protector and it didnt feel the same, just a thought.
On your Hobbit vs GOT thread i originally said id get rid of Hobbit first but since the 1.95 update Hobbit has been owning GOT here.
#3102 2 years ago
Quoted from Phbooms:
I don't think it's the playfield protector- it's the long ball times.
#3103 2 years ago
understand, game sure does have super long epic ball times. Ive had lots of 1+ hour games.
#3104 2 years ago
I've never even broken 3 million points and I know I've had games that have lasted a half an hour!
#3105 2 years ago
you got to kill Smaug before you sell it, definitely one of the best parts of the game(or any game really) in its present state of code.
#3106 2 years ago
Yeah, if I sell it I'll take off the glass and cheat and see it that way! Lol
#3107 2 years ago
I noticed that when smaug talks his voice sorta cuts out some. I remember others mentioning this also. Any known fix for this?
#3108 2 years ago
Hey guys, does anyone own a Black Arrow edition yet? Impressions? I'm thinking about buying one of these in May. I'm curious about the "Black Ink" body armor? In the photos it looks like standard black powder coating. The other editions have a high-quality coating and I'm wondering if Black Arrow is of similar quality?
#3109 2 years ago
My only opinion is that each time JJP announces yet another "LE" they devalue all the other "LE's" pretty much just assume everything they do is a "Standard" otherwise you are a fool.
#3110 2 years ago
Quoted from netman63129:
I think the Black Arrow edition looks cool.
#3111 2 years ago
I have a Black Arrow SE and love it. The powder coating is much nicer, higher quality and looks better than the flat black that you'd find on a Stern Pro. Plus, the cabinet art is different and looks better IMO. Can't go wrong with a Black Arrow!
#3112 2 years ago
Another black arrow owner here. Love the eagles so the cab art is the best imo. Black armour suits the colour scheme, it's very cool. Get one mate.
#3113 2 years ago
I get what you're saying.
The long ball times are laborious because they are necessary to progress deep into the game.
I prefer it when a good long ball represents an achievement, not a requirement.
#3114 2 years ago
I finally got around to installing the cliffy kit and when I was doing the one on the bottom I noticed the kick back screws were out quite a bit. Is it normal for those to be so loose after 800 plays?
#3115 2 years ago
that's a lot of kickback action!
Was probably loose from the factory...
#3116 2 years ago
Reminds me...I probably need to go through and tighten everything. I did that before I played my first ball because of the stories I was hearing of loose stuff. Sure enough, I could turn EVERY bolt at least a half turn sometimes more without too much effort.
Sounds like JJP needs to install a gym in their factory and buff up those installing these bad boys!
#3117 2 years ago
You might put blue loctite on those screws.
And any loose playfield screws should be glued in with titebond.
#3118 2 years ago
My post stopper for the kickback won't go up. I can go into the test menu and it does nothing until I pick up the plunger a quarter inch. I put a piece of cardboard under it and now it works fine.
Any ideas why it won't work?
#3119 2 years ago
Quoted from Mfsrc791:
Check to make sure that the rubber grommet is there! If it's not, the plunger wont activate as most of the plunger is plastic! If the rubber grommet is not there the plunger sits too low and when the coil activates it wont fire the plunger as there is not enough of the metal plunger inside the coil to activate it!
#3120 2 years ago
Quoted from meSz:
Thanks I will check that
#3121 2 years ago
Where exactly is the left kickback supposed to fire the ball? Mine launches all over the place but nowhere consistently. Should it be heading towards the right spinner?
#3122 2 years ago
Mine fires to the upper right flipper and through the spinner.
#3123 2 years ago
Quoted from Lermods:
Thanks. I have to see if I can adjust that as it makes sense for the the ball to travel there.
#3124 2 years ago
Yup I second this. And if I hold the top flipper out it hits the tip of the flipper and comes back over the rollover targets
#3125 2 years ago
What do you guys/gals think? A gold (brass plated) captive ball.
#3126 2 years ago
My Warg face broke off today :-/ $24 for a new one?!?!
#3127 2 years ago
Quoted from WackyBrakke:
They break off if they get loose.
All my beasts were super loose, I used blue loctite on the screws and so far they are holding up strong.
#3128 2 years ago
Quoted from pinballinreno:
Do you need to remove the mech to tighten?
#3129 2 years ago
Quoted from KingBW:
Really cool until the gold wears off and you have flecks of gold all over from it.
#3130 2 years ago
Quoted from paynemic:
If a little loose and you have skill and tools, no. To put blue loctite on, yes. If screws came out, yes.
#3131 2 years ago
Quoted from KingBW:
GOLD balls I got your GOLD balls!
#3132 2 years ago
Just received Hobbit Smaug SE#777 today. Pics later.
#3133 2 years ago
Mine goes in the right VUK 99% of the time. How do I turn it down a notch to have it hit the right spinner - or land right on the middle of the top flipper?
#3134 2 years ago
ooh, I like those gold balls!
#3135 2 years ago
where did you get them...and will they hold up? Are they same weight has the 'standard' ones?
#3136 2 years ago
pinballcenter
#3137 2 years ago
Quoted from GravitaR:
That's a nice lucky number! You should buy a lotto ticket.
#3138 2 years ago
Quoted from Cornelius:
or go play the slots!
#3139 2 years ago
Quoted from Goronic:
I got them from the pinball plating website
http://pinballplatingandmore.com/t/pinballs
I asked them if they would hold up enough for a captive ball application and they claim it does just fine there. I only got one to try out. they seem the same weight. I'm guessing the finish would not hold up too well with normal play, but the captive ball doesn't see much abuse.
I also got the gold (brass) plated coin slots and just installed them. It brings them out and makes them look good. Still undecided though ... maybe they should just stay black and "blend in" with the black coin door.
#3140 2 years ago
Should be in the settings menu under coils power? It will give you a warning about adjusting but try turning it down until it goes above the upper flipper
#3141 2 years ago
How do you properly test it though without starting a game? Since the post needs to be up so its in the exact position
#3142 2 years ago
Can you put the post up in the coil tests menu then test the plunger?
#3143 2 years ago
Hey I just got my LE NIB. Came with some simple frustrations, most are fixed now permanently some are band aids until I find a better solution. I will list some of those below but I am hoping you can send me a list of things to consider checking now before something else happens down the road. I want to do any preventative checks now on common issues so I don't end up with anything crapping out early because I didn't tighten a bolt.
NIB issues
loose cables/usb (LED lights werent working)
Plunger was hitting auto kicker and causing plunger not to work, ball wouldn't leave shooter lane. (Plunger still seems weak, I can't hit the top target on DWARF target bank at full plunge, is this normal?)
Right speaker wire had loose connection at speaker causing intermittent audio issues.
bar lock down mech is completely F'd, I must have played around with this for hours and it still isn't locking properly. I need a better solution for this.
Flap that stops balls from falling out when playfield is up sometime gets in the way of ball being kicked into shooter lane
All comments welcome. Thanks everyone, loving this game.
#3144 2 years ago
Weak shooter: stretch the spring or buy a stronger one. Very common issue. I replaced mine.
#3145 2 years ago
I feel like the shooter rod should be a half inch longer, it has to compress quite a bit in order to just make it beyond the auto plunge that the balls sits against.
#3146 2 years ago
Quoted from focusmediagroup:
How do the front hangers look for the playfield?
Are they bent back or bent at all?
They should be perfectly straight against the playfield.
Bent hangers will push the playfield away from the shooter.
#3147 2 years ago
I swapped for a stronger spring a while back. Worked great for a while, then stopped working so well after several months. I went back to the factory spring and more carefully adjusted the shooter rod to hit ball in center and it's been working perfectly since then.
Make sure your game slope is around 7-7.5 degrees. It will help the trough ball stop stay back. Also, my woz needed the redirecting trough bracket to be slightly bent to allow ball to properly eject into ball lane. Should be old threads on that adjustment. Double check all nuts and connections under playfield to. It's a great game once everything has been adjusted. Congrats on a great choice
#3148 2 years ago
Just picked up my The Hobbit le today.The build date was my wife's B-day,still wondering if that's a good thing. What would be a good setting for the game to play fast?
#3149 2 years ago
I think most people are around 7
#3150 2 years ago
7.2ish incline and turn slingshots power up a little. Experiment with the settings. Enjoy this awesome game.
7,000 (OBO)
Upper Freehold, NJ
$ 259.95
Pin Stadium Pinball LEDs
