(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
7 years ago
16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 11,860 posts in this topic. You are on page 236 of 238.
#11751 3 months ago
I agree with everything above from rage. I own both and will never sell either. I play my Woz the least out of all my 5 games but when I do, I just sit in awe of how dang magical that game is.
As far as hobbit, it’s maybe my most played game. It is a very long journey playing game. The multi balls can actually be very controlled and strategically used once you understand the hidden entrance lock for mode multi balls, so I wouldn’t say it’s really multiball heavy unless you choose. Killing Smaug and melting the witch are definitely two of the best moments in pinball. The 31 modes are all unique and very well done. The 3 mini wizard modes are incredibly done and reachable. TH plays different from anything else, and that’s one of the reasons I love it. Last, it’s probably the most beautiful machine ever made. I have an LE because I prefer all the characters represented on the artwork. All versions are the exact same game, just cosmetics and then Smaug and black arrow have a different attract image pop up once in awhile.
#11752 3 months ago
I keep hearing how different the gameplay is on TH and am looking forward to that. Good to hear that it is just cosmetic between the releases. Which releases came first though? Trying to get a feel for chronological ordering? Or at least machine #'s to avoid to keep with more current makes?
btw, my lineup if I go through with this will be TH, GnR LE, TZ, and original MM.
#11753 3 months ago
Quoted from iamabearsfan:
I think it went , standard , limited edition , Smaug gold , Black Arrow , I'm sure someone will correct me if I'm wrong .
#11754 3 months ago
Quoted from screaminr:
This is correct. I will add that most early machines probably got the fixes sent to them and shouldn’t be an issue.
#11755 87 days ago
My Bag End mod is damaged (the mounting 'bar' is broken at each tip)
Before I attempt a repair, could someone please post a picture of what it should look like when complete?
Here's a picture of it
#11756 87 days ago
#11757 87 days ago
Quoted from Ashram56:
Here's a picture of it[quoted image][quoted image]
Hey Ashram - sorry to see that happen I've seen a couple occasions where an airball has destroyed the base on some earlier versions of that mod.
I've uploaded a base replacement that can be 3D printed - see Thingiverse link below.
I unfortunately sold my Hobbit awhile ago - we REALLY miss it! I do believe rockrand has my old machine She's a beauty!
https://www.thingiverse.com/thing:5760384
#11758 87 days ago
Anyone think that there could be some 3D printed protector for the two VUK holes? The right one is starting to take a little wear on mine and it’s not in the area that a Cliffy covers. Any thoughts?
#11759 86 days ago
Hi guys,
how should the flippers be align on the hobbit? It s a bit hard to hit the orbit on mine, curious to hear how yours are set
#11760 84 days ago
Hello,
I’m going to be joining the club soon, just would like to know what common issues/problems to look for when buying this particular game used, and what the difference between the models are?
#11761 84 days ago
I would take a look at the Smaug for proper functions check all pop up mechs,all games are the same except for art and powder also I believe on the Smaug the splash screen is unique and the arrow may have something similar!
Love this game.
#11762 84 days ago
Quoted from rockrand:
Love this game.
Agreed, the black arrow also have black flippers bat in place of the normal yellow as well as the specific splash screen. All the games are the same otherwise.
Be carrefull with very early numbers as they did change the flaps on the popup beast (and also provided updated flaps for the one already out there)
#11763 84 days ago
Quoted from skwal:
Black Arrow had darker backglass art.
#11764 84 days ago
Also the early ramps had stainless flaps that would not sit flat and latter changed to spring steel.
#11765 84 days ago
Hey guys, still looking for some alignment guidelines for the flipper bats, anyone got some details?
#11766 84 days ago
Quoted from skwal:
Mine are just the standard, lined up with the inlanes. It shots well, can hit either ramp from either flipper.
#11767 84 days ago
Quoted from mac2444:
Do you mean aligned with the inlanes it's parallel to it or if you put a piece of plastic against the inlanes the tip of the flipper bat also touch the plastic?
#11768 84 days ago
Quoted from DrWaz:
I recall someone saying you could try some nail polish varnish .
#11769 83 days ago
Quoted from skwal:
If you have a straight edge along the inlane it should also touch the entire length of the flipper, the ball should have a straight path along the inlane all the way to the tip of the flipper. I've always thought this was the normal setup for most of the machines out there but maybe I'm wrong.
#11770 80 days ago
Is it possible to raise/lower the kick rollover?
#11771 80 days ago
Quoted from skwal:
Try adjusting the leaf blade switch below the playfield it triggers.
#11772 73 days ago
Hi, my Hobbit Le back box has no power to it. The lcd or the lighting for the backbox doesn’t work. I’ve checked the connectors. The playfield lights up as it should but the backbox does nothing. Please if anyone has some insight. I’ve checked the fuses I can visibly see. One looks different from the rest:
#11773 73 days ago
there is a service plug in the bottom of the cabinet plug something into it and se if you have power into the cab first. your plug on the back could be loose, wire worked it way off the on/off switch, start with simple first. you kinda need a multi meter to test fuses properly
#11774 72 days ago
Quoted from PinheadEDM:
You cant visually inspect fuses. You have to use a meter.
Often they blow off the wire under the metal cap, you cant see that.
#11775 70 days ago
Hey guys, i got a lot of rejects from the two left and right holes. Do you also have this issue?
The ball hot the back but come back inplace of folling into the holes
Any ideas?
#11776 70 days ago
What pitch are you playing at?
#11777 69 days ago
Quoted from wolv3:
Not sure, but i got mine at a pretty steap angle, back legs all up and front almost bottom
#11778 69 days ago
Quoted from skwal:
The over-all correct pitch should be around 7.2 degrees (glass off).
#11779 68 days ago
Quoted from pinballinreno:
I set mine at 7, is there supposed to be rubber on the metal guard on those 2 holes?
#11780 66 days ago
Quoted from skwal:
Here are pics of those two VUKs on my game; the left one doesn't have any rubber on the metal guard/bracket at the back but the right one does (it is round and blue). I only joined the club in December so I don't know why they are different (or if this set-up is stock or from a previous owner etc). I haven't noticed if one is more difficult to make vs the other - I do know that only fairly accurate shots will be successful. I will play some more and see if I should also put a rubber pad/bumper on the left VUK.
#11781 66 days ago
Quoted from Williams95:
Here are pics of those two VUKs on my game; the left one doesn't have any rubber on the metal guard/bracket at the back but the right one does (it is round and blue). I only joined the club in December so I don't know why they are different (or if this set-up is stock or from a previous owner etc). I haven't noticed if one is more difficult to make vs the other - I do know that only fairly accurate shots will be successful. I will play some more and see if I should also put a rubber pad/bumper on the left VUK.[quoted image][quoted image]
Mine’s the same way and I am the original owner.
#11782 66 days ago
I find these shots much easier to backhand then straight on.
#11783 63 days ago
Thanks, that help, i did not know if it was normal one was not there but now i know my game is as it should be
#11784 63 days ago
I'm about to tackle replacing the motor for Smaug's mouth as well as the round circuit board while I'm at it. How tough is this task...?
#11785 63 days ago
Quoted from pcprogrammer:
Pretty easy.
#11786 62 days ago
Anyone ever had their small screen go black? Half way through a game it just went black. Finished the game and cycled the game off and back on and it worked fine.
#11787 62 days ago
Quoted from Jenk540i:
Loose/worn cable?
#11788 59 days ago
#11789 44 days ago
So, now that Pinside is separating Premium and LE rating entries... https://pinside.com/pinball/forum/topic/operation-premium-le
are they going to separate Hobbit Standard and LE entries?
#11790 44 days ago
Just got a Hobbit back in the collection and the wifi won't connect to my network, it sees my network just fine just won't connect. Do you have to change registration with JJP to new owner before it will connect? It does have the Beta code so don't know if that makes a difference.
#11791 44 days ago
Quoted from manadams:
Did you give it your user name and password?
#11792 44 days ago
No.
Could be settings on your router.
#11793 44 days ago
My password yes, what username?
#11794 44 days ago
Quoted from LTG:
No.
Do you know what specific settings to look for?
#11795 44 days ago
Sorry no. It may have been posted in this thread. You can search just this thread. Or someone may post help.
#11796 44 days ago
Quoted from LTG:
Tried a different dongle that I know works with my router and still no dice, something specific with the game is causing it. I guess I'll email JJP support.
#11797 44 days ago
Is your WIFI frequency combing both 2.4 and 5GHz? I know some WIFI devices only connect with the 2.4GHz and if they are combined the machine may only be trying the 5GHz and you’d never know it. If they aren’t combined, do you see both the 2.4 and 5 separately? I’m fortunate enough to be able to run ethernet to it instead of WIFI.
#11798 44 days ago
Quoted from usafstars:
My router has both and have tried to connect to both multiple times, they are separate.
#11799 43 days ago
What brand/model WiFi dongle is in your game?
#11800 43 days ago
Going to assume you're doing this but thought I'd post the JJP instructions for GNR, I would think it's the same for Hobbit. Not at home right now to verify.
$ 49.99
Toppers
$ 125.00
Dijohn
Decorations
Toys/Add-ons
Precision Pinball prod.
Flipper parts
Armor and blades
$ 25.50
Protection
This page was printed from https://pinside.com/pinball/forum/topic/hobbit-owners-thread/page/236 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
