Quoted from pcprogrammer:Are these plastic screws just to adjust the height of the drop targets? A couple fell out on them and I put them back.
Loosen the nut, adjust the height with the screw and then tighten the nut.
Quoted from Reaper802:You need to power the servo before you install the servo horn. Then you know you are at the zero position. From there you can calibrate via the endpoint settings.
You don’t have to power the servo to set its center. You can set the center position by manually turning the servo with a hat attached. The replacement servos come with one you can use for this purpose.
Would love to see some pics of art blades and mirror blades people have installed on the Hobbit. Trying to decide what to go with.
Quoted from pcprogrammer:Would love to see some pics of art blades and mirror blades people have installed on the Hobbit.
Near the top of this thread is a gallery. Lots of pictures in it.
Quoted from pcprogrammer:Hey LTG,
I found this in the cab. Would I order this part from JJP? Do you know the part # or what it is called? I saw in other posts it comes from one of the beast mechs. Thanks.
Almost looks like it could be something like this...
Quoted from pcprogrammer:I found this in the cab. Would I order this part from JJP?
You can check with Nate if they have it.
Quoted from pcprogrammer:Do you know the part # or what it is called? I saw in other posts it comes from one of the beast mechs.
It's this.
Not sure where the screw came from. A locknut secures the target guide in place.
Quoted from LTG:Not sure where the screw came from.
If it's long enough, maybe from one of the brackets on either side of the underside of the playfield with the rod sticking out that locks the playfield to lift up and lean back.
Quoted from LTG:If it's long enough, maybe from one of the brackets on either side of the underside of the playfield with the rod sticking out that locks the playfield to lift up and lean back.
I'll keep looking. I had the playfield up and I was looking all over for a screw that was missing somewhere and I couldn't see any. So it is that exact part from MM then. It said out of stock on marco. There must be another half to it somewhere in the cab then, hopefully I can still order some more of them from JJP, I'll check with them.
No stock at JJP or Marco for this...
https://www.marcospecialties.com/pinball-parts/03-9808
If anyone has one to sell let me know. Thanks.
Quoted from pcprogrammer:No stock at JJP or Marco for this...
Funny / not funny - I just found this piece broken off in my cab as well. Where on the beasts does it go and do you need to remove the whole mech to replace it? Thanks!
Quoted from HornerSyndrome:Where on the beasts does it go
Yellow arrows on picture point to it.
This is a broken Medieval Madness assembly and the locknut is missing. But you can see where it goes. Same set up.
trollbolt (resized).jpgQuoted from HornerSyndrome:Have a Merry Christmas!
Merry Christmas my friend !
I contacted Marco. They said they are having a hard time getting this piece in. I checked pbresource and planetary pinball and they are out of stock also.
Quoted from pcprogrammer:I contacted Marco. They said they are having a hard time getting this piece in. I checked pbresource and planetary pinball and they are out of stock also.
Has anyone 3D printed this part yet? I can give it a go soon if not, but if someone has already done the model and had a file to share I’m happy to print and mail for others.
Quoted from PinballHaven:Has anyone 3D printed this part yet? I can give it a go soon if not, but if someone has already done the model and had a file to share I’m happy to print and mail for others.
That would be awesome!
I looked through every post of the 40 pages on thingverse with “pinball” and couldn’t find this piece unfortunately. But if there is a way to print one I’d be forever grateful as well!
Quoted from HornerSyndrome:I looked through every post of the 40 pages on thingverse with “pinball” and couldn’t find this piece unfortunately. But if there is a way to print one I’d be forever grateful as well!
I’m not sure I have one in my game that’s still intact. If someone has the part (preferably new as a spare) and some digital calipers to measure it I can give it a shot.
Quoted from PinballHaven:I’m not sure I have one in my game that’s still intact. If someone has the part (preferably new as a spare) and some digital calipers to measure it I can give it a shot.
I have 3-4 spares. I can post some measurements (with pics)
Quoted from metahugh:I have 3-4 spares. I can post some measurements (with pics)
IMG-4092 (resized).jpgIMG-4091 (resized).jpgIMG-4090 (resized).jpgIMG-4089 (resized).jpgIMG-4088 (resized).jpgIMG-4087 (resized).jpgIMG-4086 (resized).jpg
Often out of stock at the parts places. Used on Hobbit and Medieval Madness to keep the switch stack straight up.
Quoted from LTG:Often out of stock at the parts places. Used on Hobbit and Medieval Madness to keep the switch stack straight up.
They are definitely hard to find. I had one break years ago so and at the time I wanted to buy a number of spares for all of my beasts. Apparently I could only find 4 at the time so I have only 3 spares left
I think printing this part is the perfect use case for a 3D printer. The design is simple and it could be printed with ABS plastic.
I'd be interested in some of those plastic pieces. I found at least two in my cabinet and had no idea what they were from. My beasts work but I imagine it is only a matter of time.
Quoted from metahugh:They are definitely hard to find. I had one break years ago so and at the time I wanted to buy a number of spares for all of my beasts. Apparently I could only find 4 at the time so I have only 3 spares left
The part should have been made in Delrin or Nylon instead of brittle acrylic or whatever cheap plastic they used.
Quoted from pinballinreno:The part should have been made in Delrin or Nylon instead of brittle acrylic or whatever cheap plastic they used.
Just copied over from the old Williams days.
https://www.thingiverse.com/thing:4989264
I found this on thingverse. It’s labeled as “pinball target support”. I’m not sure if this would work but it’s close. Unsure about measurements but it would at least give you a start. I’m hoping this is the one for MM and it’s the same size. Thanks for doing this!
I guess it’s for Alien pinball but seems similar. Discription below
This is a target support specifically made for the weapons targets on Pinball Brothers Alien pinball machine. It fits over the front of the target body and fills the space in the playfield when installed. It will prevent the targets from moving out of alignment when struck on the side. it may work on other machines .
45529D7D-6557-4553-B308-73C61CA8B168 (resized).png6A4A30D3-859D-4088-B2A0-223C3152D5DC (resized).pngQuoted from pcprogrammer:Would love to see some pics of art blades and mirror blades people have installed on the Hobbit. Trying to decide what to go with.
Sorry for the glare. These were the best matching blades I found and are pretty much a perfect match to the factory art. I think these were from pingraffix, but can’t remember for sure.
89EBA626-10EF-4944-B1F1-B1A5FFE70F0C (resized).jpegBC48705E-DF08-485E-9331-C87E629A0560 (resized).jpegC6108AE7-F6AE-4FF7-A91C-3E08253B3F22 (resized).jpegEB861A05-D5D2-4952-8553-88E806C25F25 (resized).jpegMerry Christmas everyone!
I'm still suffering from a load of interference noise from all speakers on my game... whining, whizzing, squealing, fizzing, crackling etc... it seems like the earth shields of the speaker cables are simply not earthed... if I were to simply connect the earth shield to an earth in the game (like an earth strap for example), would that be a stupid thing to do? I.e. would it cause some sort if short that would damage the sound board, or is it a possible safe solution? Not sure how earth shields are wired up...
Even in attract mode it's doing it.
Thanks for any advice!!
Quoted from pinballslave:Merry Christmas everyone!
Bypass the ground loop isolator (odd little black box that the speaker wire is plugged into) and plug the speaker wire directly into the green hole in the back of the computer.
Ground loop isolators go bad or dont work right and cause all sorts of noise.
If that helps, buy a new one.
Quoted from pinballinreno:Bypass the ground loop isolator (odd little black box that the speaker wire is plugged into) and plug the speaker wire directly into the green hole in the back of the computer.
Thanks for the tip! I'm not with the game right now, but will see if this works (and if I understand your description) when I'm back with the game in early Jan.
Thanks again!
I did take a photo of the 'sound board' in my game before I left home in case it was useful in helping understand this problem, see below...
Is the ground loop isolator, speaker wire or green hole shown in this pic, or do I need to look somewhere else for these things?
Screenshot_20211225-195457_Samsung Internet (resized).jpgQuoted from pinballslave:Is the ground loop isolator, speaker wire or green hole shown in this pic,
D-102 in the manual has the green going to the sound amplifier board.
Follow the wire from the ground loop isolator. It's a small black plastic box with a cable sticking out of each end.
Quoted from LTG:D-102 in the manual has the green going to the sound amplifier board.
Its not in the computer box, Its behind it sitting on the floor of the cabinet.
Has a wire coming out of it on both ends.
Quoted from pinballinreno:Its not in the computer box, Its behind it sitting on the floor of the cabinet.
Thanks for your help!
I'll look in the game when I'm back with it... So of the 6 cables in the pic I posted, is it one of those that should eventually be connected to the ground loop isolator?
Quoted from pinballslave:ground loop isolator?
Look around inside the metal box with the boards and along the back wall of the cabinet. There might be two.
It's the only thing like it in there. Small black rectangular plastic box with a cable coming out of each end.
Hi, i'm fixing a few problems on a Hobbit right now. Most of them are sorted out, but there is 1 "problem" i can't figure out.
De stepper motor of the Smaug head is extremly hot. You can't put a finger on it. The head is moving freely from left to right in test menu.
What causes the heat? I don't think this heat is normal?
Greetz Dennis
Quoted from LTG:Short in the motor windings ?
Then it wouldn't turn left and right i suppose? That is working flawless without any hesitation
Quoted from Denden1978:Hi, i'm fixing a few problems on a Hobbit right now. Most of them are sorted out, but there is 1 "problem" i can't figure out.
Greetz Dennis
Mine works fine, but has always been very hot.
Quoted from metahugh:[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Thanks for the measurements! Prototype done, ABS filament ordered. Will check for fit on my hobbit Friday, work stuff keeping me busy this week.
0F528B3A-4913-42F8-AAB1-3836B9AC645B (resized).jpegB29702E0-ECA5-47F8-BF93-C4F8FA175B19 (resized).jpegC80EF47E-972D-4127-A2E2-A2FB2D930DE3 (resized).jpegQuoted from PinballHaven:Thanks for the measurements! Prototype done, ABS filament ordered. Will check for fit on my hobbit Friday, work stuff keeping me busy this week.
Looks perfect!
I've only had my Smaug a few months and a consistent issue I seem to be having - left ramp shot returns ball to right inlane but almost half the time it bounces to outlane. Wondering how common this is and if anyone may have invented a fix?
Quoted from adamross:Wondering how common this is and if anyone may have invented a fix?
Lower the flipper strength. Make sure it isn't bent. Maybe raise it a little to slow the ball down. Things like that.
Quoted from adamross:I've only had my Smaug a few months and a consistent issue I seem to be having - left ramp shot returns ball to right inlane but almost half the time it bounces to outlane. Wondering how common this is and if anyone may have invented a fix?
Bending the end of the wire form to close the gap in the upper and lower wires helps, you can adjust the wire a bit side to side also. Just mess with it some and it should settle into a better spot with some patience. Mine did that when I got it a bunch, but it can be fixed.
If the ball is spinning up and out of the lane, bend both the lower and upper end loops of the wireform ramp, up (away from the playfield, towards the ceiling) about 1/4".
This changes the trajectory of the ball as it drops into the lane and eliminates the spin out.
Just stick a 1/2" nut driver in the loop and bend it up a bit.
Looking good! Thanks for trying this out!
This page was printed from https://pinside.com/pinball/forum/topic/hobbit-owners-thread/page/222 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
