(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
6 years ago
  • 11,588 posts
  • 694 Pinsiders participating
  • Latest reply 5 hours ago by LTG
  • Topic is favorited by 267 Pinsiders
16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 11,588 posts in this topic. You are on page 190 of 232.
#9451 1 year ago
Looking to replace the ramp flaps on my Hobbit, however JJP only sent me the first 2 pages of the 3 page instructions. I have contacted them several times, but still have not instructions. Can someone scan and send me the pdf. Just did the Cliffy's. Might as well get the rest completed. Thank you in advance.
#9452 1 year ago
Quoted from eroomnek:
Send a pm to pinballomatic, see if he has them.
#9453 1 year ago
I know the points scored in the Arkenstone mode depends on the prior mode you do but clarification- is it just the last mode you play or the last mode you compete or which mode matter for scoring? If it just the last one you play before going in than is it better to complete an easier mode or try but fail a hard one?
#9454 1 year ago
Quoted from HornerSyndrome:
Highest-star mode completed, order doesn't matter
#9455 1 year ago
I’m having sound issues with my hobbit. It works fine sometimes when I first turn it on but after a few plays the music is playing but the call outs are very muffled - almost can’t hear them at all - and sometimes the stereo surround fades from left to right. I hope this is just some loose audio wire but I’m clueless. Any help would be greatly appreciated! I don’t have a hum or loud noise like what sounds like the ground loop isolator problem was - it’s lack of sounds and mostly call outs.
#9456 1 year ago
i had same issue. i replace the audio board and the ground loop isolator but nothing solve it but i just replace the aux cable and its solve it! please buy a better Aux cable and replace it. most of hobbit machines have cheap Aux cable who made many issues. i bought really good one and have awesome sound!
this is the one i use and they are awesome
amazon.com link »
i also change it to my other machines and it made the sound much much better!
#9457 1 year ago
Remove the ground loop isolator between the computer box and the speaker.
its way in the back behind the computer box on the right maybe.
#9458 1 year ago
Quoted from pinballinreno:
looks something like this, maybe a bit shorter and fatter:
amazon.com link »
#9459 1 year ago
You can also plug in headphones straight in the computer, bypassing the power amplifier. If you can hear clear audio, you know it's not the computer motherboard. It's pretty rare to have the motherboard audio jack fail though. But, if it sounds like crap out of the motherboard, take it from there.
#9460 1 year ago
Thanks everyone for your help. I tried replacing the cable per Lior’s suggestion. Only played a couple games since but so far so good! Thanks again all! Love this game and it’s call outs!
#9461 1 year ago
Does anyone have a link to a good rulesheet image for the custom graphic?
#9462 1 year ago
Does anybody have any pics of the art blades from pingraffix on a game? I’m debating on the two options they offer and would like to see how they both look installed. Also, is a blade protector needed on hobbit and woz for the blades or not? Thanks
#9463 1 year ago
Quoted from konghusker:
I use blade protectors religiously.
Its a good habit to develop after damaging a couple games.
#9464 1 year ago
where did you get the protectors? Thanks
#9465 1 year ago
I have 2 sets now, one for the shop, one for the gameroom.
With a little maneuvering they fit inside most games thru the coin door.
https://www.pinballlife.com/interior-cabinet-protector-blade-set.html
#9466 1 year ago
Perfect. Thank you
#9467 1 year ago
What's the best stuff to use to clean the black crap off the rubbers .
I'm thinking detergent on a rag ( soapy water ) but is there anything better .
I did read somewhere to use lighter fluid and I also thought about methylated spirits but wouldn't that be corrosive on the rubber .
#9468 1 year ago
Step 1: Make a Titan order and replace the junk stock rubber. https://www.titanpinball.com/kits/index.php/view/id/1081
Step 2: Clean with Naphtha. NEVER use water on a pinball machine! NEVER!
#9469 1 year ago
Quoted from screaminr:
[quoted image][quoted image]
Yes VM&P Naptha or lighter fluid (same thing) works, and is a must have for cleaning mechs, coil sleeves and plungers.
If you want to get fancy RC-88 rubber cleaner does actually work better. Its mostly naptha with a detergent, but smells horrible:
https://www.pinballlife.com/wildcat-rc-88-rubber-cleaner.html
The stock rubber plays ok on this game, but in my opinion, after trying them all, Perfect Play opaque green plays the best on this game.
I did not like the Titans.
#9470 1 year ago
The way they play? The way they look? both?
#9471 1 year ago
Quoted from fnosm:
The way they play.
However I have super bands on my IJ (tough to install) and they work well.
Urethane has a "dead bounce" feel, it works pretty good on a lot of games.
I choose flipper fubbers based upon how they play on each particular game.
Some games need bounce, some need less bounce, some need ball control etc.
I have Titan purple on my Houdini.
Perfect Play on my WOZ and TH.
#9472 1 year ago
In Australia, Mr Sheen. Use it for rubbers and playfield. Brilliant.
#9473 1 year ago
Perhaps the Titan “Low Bounce” flipper ring variant behaves like the Perfect Play rings?
The way they play.
#9474 1 year ago
Quoted from Trumpanche:
I think its very similar, or the same stuff.
#9475 1 year ago
Everyone I know that has tried the new Titan Low Bounce LOVE them. I'll be switching my games over very soon.
#9476 1 year ago
I have black flipper rubbers on my BA so don't see dirt. Black rubbers would look ok on the yellow bats, or you could replace the bats and rubbers to black.
#9477 1 year ago
Quoted from TOLLS:
Thanks mate , I have some in the cupboard .
#9478 1 year ago
Quoted from punkin:
Once you go black...
#9479 1 year ago
Quoted from punkin:
How hard is it to change out the bats? I haven't done that before. Also, which do you recommend I go with to go on a JJP? Should I just contact JJP (or check their online store) for the ones that they use in the Black Arrow edition? (I have the yellow ones that come with the Smaug Gold Edition).
You know...while I am at it I wonder how the flipper buttons would look if I switched them from the yellow ones to black???
#9480 1 year ago
I'm the wrong guy to ask mate, only had pinnies for 18 months.
#9481 1 year ago
Quoted from Goronic:
Easy if you can work a wrench.
#9482 1 year ago
Hello everyone, I have been asked for pictures of the installation of the second screen I hope this will help you have a good weekend
17FD4B7E-C67B-4AB7-823A-F1D314CB519B (resized).jpeg3A8DFD7F-9D4F-4CA1-A974-F48DB5FA1C57 (resized).jpeg4AC6015B-8525-4826-A09B-7A639ED14EF6 (resized).jpeg7A140C60-BC55-4A5B-BBFA-F8B5AC76CAA7 (resized).jpeg96CC722E-56AF-46C0-9471-433BCAF8AF4C (resized).jpegA29C8D73-F718-4A63-B0C6-1180EEDCF0E9 (resized).jpegB6D634DC-41F0-46ED-9345-ECC1114228CE (resized).jpegD02C696A-E5D5-41A0-9AE9-4FF873EAF1BA (resized).jpegE0B01120-515D-437C-9179-FD88CD598372 (resized).jpeg
#9483 1 year ago
Quoted from Fred550:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
I would like to know more about that glass cover!
#9484 1 year ago
What modes do you guys go for if your trying to get a good mode score? My strategy is to get resurgence of Sauron then rip spinners and shoot the left ramp when you're getting low on time. You can get 10k+ per ramp. Makes for a lucrative treasure hunt mode too.
#9485 1 year ago
https://www.marcospecialties.com/pinball-parts/CP-100
This stuff is great for rubber cleaner, also great for playfield light cleaning.
#9486 1 year ago
Fred550 - thanks for the pics - awesome job with the mod!
#9487 1 year ago
thank you very much I send you the links
for all that is pinball pad
Super serious
the right corner a used site
https://www.facebook.com/Design-Flip-arcade-1201857069992288
https://www.leboncoin.fr/collection/1891573918.htm
#9488 1 year ago
Quoted from TOLLS:
I found some contact cleaner and decided to use that , it said it was non-corrosive , safe on plastic , left no residue and was fast drying .
The white rubber came up looking like new , same with the stand up targets and the Flipper rubbers are a lot better .
I just sprayed a little bit on a microfiber cloth and gave it a wipe and it came straight off .
IMG20201213171926 (resized).jpgIMG20201213200545 (resized).jpgIMG20201213200742 (resized).jpgIMG20201213202712 (resized).jpg
#9489 1 year ago
The N on my man Target won't pop up , the spring looks fine , it pops up during coil test and I can't see any broken ledge pieces .
Found these two screws in the cabinet , don't know if they have anything to do with it .
#9490 1 year ago
I'd check the brackets holding the coil that shoves it up. If the studs the nuts go on shear off, binds things quite nicely. Or broken coil sleeve.
That holds it when up, doesn't effect going up.
Black one looks like a coil stop screw ? The other one looks like it holds bracket on, one on either underside edge of the playfield with the post sticking out ?
#9491 1 year ago
Quoted from LTG:
Thanks as always Loyd , I'll check it out when I get home .
#9492 1 year ago
Is there a setting to turn off beasts on hobbit pinball? My beasts are not popping up. All 4 of them. The light still shows up as if the shot is there
#9493 1 year ago
Quoted from Vernisious:
Did you clip the tie wraps that hold them down in shipping?
#9494 1 year ago
To whom ever in the factory drew this face on the coil connector to my Orc pop up. The answer is it ended up in Australia.
#9495 1 year ago
Happen to be fixing a pop up. Cable tie as in photo or the wires can sever and bind.
My cage need removing then, loosen 4 screws fixing the toy end, align the coil stroke with the pop up stroke so it freely moves, then tighten. First one worked well but used the bottom 4 screws in order to maintain a true alignment when reattaching to the pf. Top 2 float. Pull the Spider and have a play. Don’t disable, gotta fix it or you will end up selling and regretting.
There are other fixes in this thread. This worked for me.
#9496 1 year ago
If you did this -
Quoted from Pinballomatic:
Then yes. You can turn them off in Game Settings page B-33 in the manual. Near the end of Game Settings in the menu under Pop Up Mechs - towards the end of the Game Settings.
Or you can fix them. Loosen the nut on the bottom of the assembly and above it spin the rubber stopper a little higher and retighten the nut for a start.
#9497 1 year ago
You're the man Loyd .
The black one was a coil stop and the silver one went into the end of the rail , hard to see when the playfield was lifted up .
#9498 1 year ago
Newbie question- how sensitive are your “LOCK” rollover targets? For example if I cradle the ball and shoot for one of ramps and rollover the target it is too fast to register a rollover - so I can’t really shoot directly for them - mostly I get them from them rolling back after I hit a beast or if it doesn’t make it up a ramp or sideways cross playfield shots.
If these should be more sensitive then when I adjust the leaf switch do I slightly bend the long leaf closet to the playfield down away from the playfield or do I bend the shorter lower leaf up towards the playfield? Or something else all together? Thanks in advance for the help!
#9499 1 year ago
Quoted from LTG:
Lloyd: Great video for the flippers on JJP. I've got a Stern POTC and just did a flipper re-build. The bat is attached via an allen wrench 5/32". I tighteneed to what I thought was a good torque only to have the bat continue to twist. I'm afraid to torque it much more? Is there a Lock-tite type product that would seize it up and still allow disassembly later? Or do I just ball bust it tight?
#9500 1 year ago
Quoted from gordonshumway:
I use a small 6" ratchet/socket wrench and a 3/8" socket to tighten the pawls.
You can tighten them a lot until the pawls close completely (you can see the gap).
Too much tightening can break off the bolt, so dont go too far past where the pawl gap closes completely.
That said, you can tighten them a lot to get the bats firmed up.
They will tighten effectively without any loctite.
Make sure the bats have some in and out movement and are NOT dragging on the flipper bushing or dragging on the playfield.
3/64" of gap is perfect, or a thin credit cards width.
12,200 (OBO)
Tampa, FL
Hardware
Hippies Haven
Precision Pinball prod.
