(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
8 years ago
  • 12,997 posts
  • 745 Pinsiders participating
  • Latest reply 45 hours ago by LTG
  • Topic is favorited by 272 Pinsiders
16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 12,997 posts in this topic. You are on page 185 of 260.
#9201 3 years ago
Quoted from Travahontas:
pinballinreno 7.1 degrees WHERE? My playfield seems to be bowed by about a degree from the ramps to the flippers... I currently have it set at 7.5-ish at the ramps and 6.5-ish at the flippers. Shoots good enough for my skill level I think?
Anyone else have this kind of inclination difference from the top to the bottom of the playfield?
Almost every game is like that, which is why I always ask specifically where people are measuring.
Also take into consideration that inserts, even slightly raised will throw off the level.
I use the same torpedo level that you have, and also a small one that fits just about anywhere on the pf.
But I find the change in slope from top to bottom more drastic on Hobbit than other pins I've levelled.
Not exactly sure why.
#9202 3 years ago
My Hobbit sits around 7.3 incline. Just scored 3,695,XXX. Killed Smaug and played all three Arkenstone mini-wizard modes. The through issue I've been having still happens from time to time (about every other day). I had tightened the connectors at the opto board, but tonight I did the same at the I/O board. Tugged on all the wires and did not notice any loose ones. Then I went on a game that was over an hour long with no issues, so hopefully that is the end of that (fingers crossed).
#9203 3 years ago
Question for everyone: how hard is it to update the code? Will I still keep all my scores? I'm running version 2.96 and I noticed that the game forgot I was Into The Fire champion. Read up on it and sounds like that was an issue which was addressed by a code update.
Second question: what is everyone's recommended maintenance schedule? How often do you clean and wax the playfield? Do you have to grease the gears on the Smaug head every certain amount of time?
#9204 3 years ago
Yup. Lots of weight in those mechs. Quite a bit of flex in the Pf.
#9205 3 years ago
measure in 3 locations and try to get an average, its the best you can do.
#9206 3 years ago
Quoted from GTO:
Its easy to update the code.
Back up your settings and scores before you do it.
I save them on a separate flash drive and then copy the files to a folder on my computer for safe keeping.
You never know when a SSD drive will fail. I keep backups periodically whenever a new hi score is acheved.
#9207 3 years ago
Quoted from GTO:
I wax the playfield and replace the balls every 350 to 400 games played.
My game looks like brand new after thousands of plays.
Probably not a bad idea to inspect Smaug every waxing.
#9208 3 years ago
Quoted from pinballinreno:
No dimpling? Mine shows some dimpling already due to the ocassional airballs. Otherwise, no other playfield issues. I bought it with 82 games played and I'm probably up to 120-150 (haven't checked the number recently).
#9209 3 years ago
Quoted from GTO:
Dimples are normal and even out after a few thousand plays.
#9210 3 years ago
What are used for the post sleeves in this game? Are they just standard post rubbers, or thinner?
#9211 3 years ago
I'm installing a lighting mod and need a splitter to grab power from the topper. What type of connector is that?
#9212 3 years ago
Quoted from WizardsCastle:
I switched from Titan Standard post sleeves to the Titan Stern Tapered post sleeves and have been happy with them. I have a full color matching kit uploaded to the Titan website with photos. Those photos can also be found in this thread.
#9213 3 years ago
Quoted from Reaper802:I switched from Titan Standard post sleeves to the Titan Stern Tapered post sleeves and have been happy with them. I have a full color matching kit uploaded to the Titan website with photos. Those photos can also be found in this thread.
I need to shop out my Hobbit. I just ordered your "kit" from Titan. Thanks for taking the time to do this... looks great.
11
#9214 3 years ago
My book screen stopped working about a month ago trouble shot it and decided the screen needed to be replaced. I called JJP and they told me the screen was going to be around $70. I found a replacment for $30 shipped.
https://www.buydisplay.com/lcd-4-3-inch-tft-display-module-in-480x272-vga-video-av-driver-board
I ordered it on the 21 of September and came today. Installed and works great.
#9215 3 years ago
Someone on the GNR hype thread said The Hobbit Playfield was bare and lacked shots .
I thought I would correct him .
Did I miss anything .
#9216 3 years ago
Dude. The playfield DOES look bare. I dont blame people for that impression. But it is packed af.
#9217 3 years ago
Quoted from Doctor6:
Just because it looks bare , doesn't mean it is . There are 4 bash toys in the middle of the playfield ( as you know ) .
If someone says the Playfield is bare as a statement of fact , it should be pointed out they're wrong .
#9218 3 years ago
Quoted from BazilBLast:
I'm simply saying that I don't blame first impressions. It is idiotoc to not play it and run your mouth saying it is bare/boring, as the game is absolutely incredible.
#9219 3 years ago
I sold this game about a year ago and greatly miss it. It doesn't have much shot satisfaction like loops or ramps you want to hit over and over again but it has some of the best pinball "moments" that I have ever experienced. For example, in Stranger Things the first and second wizard modes have no energy. I don't really care if they end quickly because I never emotionally get pulled into them. Hobbit is the exact opposite. Its wizard modes are incredible and pulled me in every time. Not to mention trying to kill Smaug, I don't think I've every been more invested in a game then when you have that one shot left to kill him.
So why did I sell it? At the time it was either own this 1 game or 2 other games. I decided to go with options instead of just 1. Also my non pinball friends were intimidated by it. There is so much going on that they really never had any idea what to hit or shoot for. With that said... If they ever add coop mode to this game I WILL buy it again. That way I can work with my friends/family and explain what WE are trying to accomplish together instead of them just watch me play.
#9220 3 years ago
Put it on 10 ball play and go. CoOp solved.
#9221 3 years ago
People say this all the time but it is not the same. You want to keep the players separate with a separate coop score table.
#9222 3 years ago
Quoted from joelbob:
And you don't want a high score to save in this scenario....
#9223 3 years ago
Quoted from Sijcolo:
Wow, thanks for sharing.
I've been having issues with my small LCD screen losing blue colors intermittently.
Knowing this screen works (at a much lower price) will stop my procrastinating and I'll just replace the damn thing.
#9224 3 years ago
stupid question (for people like me) what options do we order?
#9225 3 years ago
You don’t need the touch panel or the remote. Just the basics. Also on the metal piece that holds the screen I had to adjust it. Mine was digging into the the cable between the board and the display.
#9226 3 years ago
The kit comes with the screen and board. It was a very straight forward replacement.
#9227 3 years ago
I'm having an issue plugging the copper cable into the board. Suggestions
#9228 3 years ago
Quoted from Jeffswack:
I'm having an issue plugging the copper cable into the board. Suggestions[quoted image]
The white connector has a brown bar on the back - see it? You have to flip that forward, insert the cable and then push the brown bar back down.
#9229 3 years ago
LOL - this is great. Everyone's obsessed with subways - might as well mention those too And doesn't that mean 4 holes? Balin, Radagast, Smaug & Erebor? hmmm...
#9230 3 years ago
#9231 3 years ago
Is it just me, or do you guys also love hearing Azog's laughter at the beginning of Into The Fire?
#9232 3 years ago
Quoted from GTO:
Nope you are not alone, absolutely epic!
#9233 3 years ago
Can one of you guys with the new screen get a picture of it in action? I know this is a low res display but I always felt like the JJP supplied LCD was kind of low light washed out looking. I'm curious if the replacement is any better quality. I ordered one because JJP doesn't have any listed in their store.
#9234 3 years ago
I'm not home to grab q pic but it did seem a little brighter
#9235 3 years ago
Does this game use standard post sleeves, or the thinner Stern style?
#9236 3 years ago
584C1832-E73F-4461-9F26-47527CC2CDC5 (resized).jpeg584C1832-E73F-4461-9F26-47527CC2CDC5 (resized).jpeg674A68AA-97D4-4852-A4D5-987ADE00FCDD (resized).jpeg674A68AA-97D4-4852-A4D5-987ADE00FCDD (resized).jpegBBEE8B44-9875-464F-ABDA-B5263EF4B2C4 (resized).jpegBBEE8B44-9875-464F-ABDA-B5263EF4B2C4 (resized).jpeg
#9237 3 years ago
Sorry about the blurry picture my phones fault.
#9238 3 years ago
Looks perfect.
#9239 3 years ago
Looks red to me
#9240 3 years ago
It looks more red in the pictures then how it is in the game.
#9241 3 years ago
I think that actually looks better than the screen I have. I understand some colors are a real bugger to capture. It definitely looks like colors are more prominent in the new LCD. Thanks for taking the time to post pics.
#9242 3 years ago
I recommend the Slim Tapered Stern style from Titan. That's what I put in the kit I build for Titan after testing standards.
#9243 3 years ago
Beat Smaug last night which is pretty epic, and then got to the three mini wizards. I had one ball left, so thought maybe I could try for TABA. I decided to cheese it, and time out all the modes. Got 21 of the down, but then the mode ramp would not like light.
I read in the rules that modes first need to be qualified? How do you qualify all the modes?
#9244 3 years ago
By playing the game, shooting all the drop and standing targets, holes, ramps, etc...
#9245 3 years ago
Quoted from fnosm:
Is there a way to qualify all modes earlier on? Or how can you tell what needs to be hot to qualify?
Like in LOTR, I know to hit the white shots to start the mode.
#9246 3 years ago
The modes are made "available" when you qualify "either" Gandalf, Bilbo or Radagast. Once that's obtained they modes become available/changeable via shooting the left ramp.
Scroll down to modes section:
http://tiltforums.com/t/hobbit-pinball-rulesheet/1360
#9247 3 years ago
You also need the ELF, MAN, and, DWARF targets. Some modes require more than one qualifier. Take some time and watch the Buffalo Pinball vs JJP Hobbit head to head battle on YouTube, it will answer all your questions.
#9248 3 years ago
Updated from version 2.96 to 3.10. Really enjoy having the added callouts, light sequences, and tracking of the completed stages in the Arkenstone modes. Also, am I crazy or are the green lights shining on the bottom of Smaug new? Well, probably not "new" since the bulbs are already there, but definitely used more in non-Smaug multiball sequences so that I got to notice them now.
#9249 3 years ago
I got my Lior mods in and they look AWESOME. As always great quality and fun times adding them to my games.They definitely make the games more high end even though JJPs are already great looking. The legs hanging out of the barrel is totally funny and if you know the story totally fitting for the game:}
IMG_7704 2 (resized).jpegIMG_7704 2 (resized).jpegIMG_7705 (resized).jpegIMG_7705 (resized).jpegIMG_7706 2 (resized).jpegIMG_7706 2 (resized).jpeg
#9250 3 years ago
Quoted from Crumbalimb:
Who sells those Mods they look great
9,200
Cedar City, UT
9,250
Mt Zion, IL
$ 64.00
Pixels Arcade Games
$ 259.99
$ 25.50
$ 11.95
$ 120.00
$ 18.00
Volcano Pinball
Pinball Invasion
10,500 (OBO)
North Myrtle Beach, SC
$ 79.00
Pixels Arcade Games
10,000 (Firm)
Leesburg, VA
$ 39.00
Travahontas Mods
$ 90.00
RavSpec
$ 49.99
$ 125.00
Dijohn
$ 95.00
Pinball Mod Co.
$ 50.00
Duke Pinball
$ 130.00
Dijohn
This page was printed from https://pinside.com/pinball/forum/topic/hobbit-owners-thread/page/185 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
