(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
  • 8,830 posts
  • 556 Pinsiders participating
  • Latest reply 3 hours ago by Bendit
  • Topic is favorited by 208 Pinsiders
There have been 1,245 images uploaded to this topic. (View topic image gallery).
16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 8830 posts in this topic. You are on page 175 of 177.
#8701 48 days ago
Quoted from Goronic:
Check the very back of the play field. There is about a half inch gap along the back that I have had to retrieve countless screws, nuts, and springs...
Any advice on how to dig back there without having to take it apart? I can’t get a good angle at all to dig in there
#8702 48 days ago
Quoted from pinballinreno:
A good playfield pitch for hobbit is 7.1-7.2 degrees, measured on the playfield not on the glass.
I feel dumb asking this-- but what do you use to measure the pitch?
#8703 48 days ago
Quoted from coloradodan:
there are alot of phone apps that you can use for this.
Also you can buy levels at your local hardware store with angle meters(if that is a good name for them.)
Here is link to a google search on digital level:
https://www.google.com/search?source=hp&ei=V93PXvzOJITU-gSVjqrIAQ&q=digital+level&oq=digital+level&gs_lcp=CgZwc3ktYWIQAzICCAAyAggAMgIIADICCAAyAggAMgIIADICCAAyAggAMgIIADICCAA6DggAEOoCELQCEJoBEOUCOgUIABCDAToECAAQA1DiD1jzHmDLIGgBcAB4AIABRogBoAaSAQIxM5gBAKABAaoBB2d3cy13aXqwAQY&sclient=psy-ab&ved=0ahUKEwi81qeZ9NbpAhUEqp4KHRWHChkQ4dUDCAk&uact=5
#8704 48 days ago
Klein Tools 935DAG Digital Electronic Level and Angle Gauge, Measures 0 - 90 and 0 - 180 Degree Ranges, Measures and Sets Angles amazon.com link »
This is what I use, not sure if its the best tool for it but its pretty good at getting the right pitch and leveling out my machine
#8705 48 days ago
Any good digital torpedo level. Here is one example
amazon.com link »
#8706 48 days ago
Quoted from wizman71:
Same! I just picked up the smaug gold edition with 106 total plays! I was hunting for The hobbit or LOTR LE, probably going to try and get a hold of LOTR in the very near future but im excited to put way too many hours in on this thing!
I seriously doubt your game is that old with only 106 total plays... play counts reset if you do a factory settings wipe from the menus. There's no great way to tell the full playcount of the machine. But don't sweat how used it is, it's a fantastic game as you know.
#8707 48 days ago
Pull the playfield all the way out and stand it up against the backbox. Rubber piece should fall and end up in the bottom of the cabinet.
It's there somewhere!
#8708 48 days ago
Got it! A good $30 investment. Also, thanks to fnosm for googling that for me
#8709 48 days ago
I use one of two methods to retrieve an item that may have rolled/fell to the back of the playfield.
1. If it is metal I used a magnetic head screwdriver or nut driver to get it out (done this SEVERAL times)
2. If it is NOT metal I put some reversed masking tape to the end of a flat head screwdriver or old butterknife and then allow the item to stick to the tape and then slide it out.
Those two methods seem to work the best for me...
NOTE: if the item is directly behind the ramps or Smaug you may need to slide it to the pops side to get better access to the item - or use the same technique but on a tool that is very low provide or can be bent.
#8710 48 days ago
Get a bubble level app for your phone, in a pinch.
They vary as far as accuracy.
Take the phone out of its case for better results.
A digital torpedo level is best, get a small one, 9" or shorter.
amazon.com link »
Also you can get a small inclinometer .
amazon.com link »
#8711 48 days ago
Did you guys see the post on Facebook that JJP said that all their machines should play at 6.5 if the leg levelers are screwed in flush and just adjusted if the floor is not level. If that is the case I bet I am playing my hobbit at 7.5 or 8!
It does play fast this way - which I have gotten used to. I am not sure I can go back to 6.5 (if I am way over it now).
Going to get a digital level to double check for sure...
#8712 48 days ago
My pitch is 7.1 - 7.2 with a digital torpedo level... Played around with different pitch and this seems to be the sweet spot for me.
6.5 was way too slow
#8713 48 days ago
I literally laughed out loud when I saw that post they made. Hobbit needs to be at 7.2* or more. Otherwise I would understand why people think it's a boring slog. I read about these two hour games and can only imagine how flat those playfields must be. My LE at 7.2* is an evil mistress. That is the sweet spot for sure.
#8714 48 days ago
The "6.5 degree with leg levelers all the way in" design didn't start until DI when Pat wanted it that way. WOZ and Hobbits (at least made before DI) are not designed that way. I think it was a new guy at JJP that generalized it when posting that. You need a level floor for that to work even with that designed into them (or come close at least). I like that design concept. Thanks Pat! I'm sure he rarely reads Pinside.
#8715 48 days ago
Houdini is designed the same way i believe.
#8716 47 days ago
Here is my legs at 7.2. It was around 5 before. Wow, it's a lot faster now!
#8717 47 days ago
I'm sure this is why a lot of people didn't think this game played well and was too floaty.
#8718 47 days ago
After dozens of trials, i found that 7.1-7.2 is the sweet spot.
Adjust flipper power so that you can barely make either ramp from either flipper from a cradled position.
#8719 46 days ago
Where can you set the flipper power?
#8720 46 days ago
Settings -Coils, in the manual pages Settings B-22 Coils B-36
If you need the manual you can download it from jerseyjackpinball.com go to Support go to Downloads go to Hobbit go to manual.
#8721 46 days ago
Just finished Riddles in the Dark for the second time ever and went Into the Fire at 4x. One Warg away from starting Level 3, only 400K for the Mode. Man it stings when you know you just wasted a shot at a monster number. Keefer is the man.
#8722 46 days ago
Lermods translite surround LEDs installed. Very nice upgrade, I highly recommend this mod!
217CD8C6-D50A-409F-BBEB-E2F2091FC6D4 (resized).jpeg2FE551A5-986D-433C-85C9-1A316DF1790F (resized).jpegB4B12DBD-20CA-4F80-A069-ADCE3C2B3591 (resized).jpeg
#8723 46 days ago
To each his own.
#8724 46 days ago
Quoted from darkryder:
Way to much light behind the translite and behind the pin for my tastes.
#8725 45 days ago
The controller has a brightness adjustment, I might tone it down a little.
#8726 45 days ago
Killed Smaug last night for probably only the 4th time in several years. Man what a great game. I seriously need to play it more often than I do.
#8727 45 days ago
Quoted from konghusker:
So, I still haven't done it. I ALWAYS choke on the last shot. Now, my 12yo kid JUST did it last week for the first time ever. (I've owned it for about two years) Unfortunately, I was on a conference call for work so I couldn't see the sequence of events. Also - I lost money since I had a $5 bounty on Smaug's head this month
#8728 45 days ago
Quoted from PinballCharlie:
S I was on a conference call for work so I couldn't see the sequence of events.
You can see it here...
#8729 45 days ago
LED's always come off brighter in pictures, so with that being said I also have the mod installed. It looks SOOOO much better than not having anything. (My pic also looks fairly bright - it's lit up to the same brightness as the top).
https://images.pinside.com/6/0f/60f2c5422d03805def5d3c7a4892e8c7648300fa/resized/large/60f2c5422d03805def5d3c7a4892e8c7648300fa.jpg
#8730 45 days ago
So do you guys/gals feel like the market on this title has finally plateaued or do you think that this title will continue to drop in price? And if you think it'll drop more in price where do you see the bottom?
#8731 45 days ago
Quoted from CLEllison:
Being I find it an incredible value now, I don't see why it would keep going down. But what the hell do I know? I love this game to death and some flat out hate it.
#8732 45 days ago
You folks at 7.2 and such, did you have to bend the ball trough a bit for balls to shoot out properly?
I think I need to do that, after having lowered it back down some, and it still smacking the trough.
#8733 45 days ago
Quoted from wesman:
Yes the trough needs to be bent. Super easy to do, just go it a little at a time. Run several eject sequences to ensure it's constantly succesful.
#8734 45 days ago
I just installed the pin worlds Bag End into my game. At first the wires were showing. Charles at pin worlds suggested the obvious to paint the wires black. I used Sharpie paint pens and a regular sharpie to get close to the mod and missed areas. It looks great.
#8735 45 days ago
I don't know. None of this makes sense to me at all. I thought collectors looked for games with awesome assets and theme integration like Hobbit has. Everything about it is top notch and it gets shit on. I think it's mostly because people set it up wrong. But I thought pinheads who own machines would know better. Apparently not. How can LOTR rate so much higher than Hobbit? Blows my mind! I got 7 grand into my Smaug with radcals, plastic protectors, pinblades, full set of Cliffy's, ramp and trough and undercab lighting, and updates done. No way in hell I'm ever selling it for under $6500.00
#8736 45 days ago
Quoted from Mr_Outlane:
I think you hit the nail on the head. If the pitch is at 6.5 it's just floaty and slow and just not fun to play. If I might also add, the early code was pretty bad. Not because I own one, but because it truly is one of the best pins and bang for the buck in the JJP realm. But I also think you have to be a Tolkien nerd to really enjoy this, as it is a journey only those of us "in the know" will truly enjoy. I have hopes, that this will become equivalent to what happened to so many titles before it. Twilight Zone is a PRIME example. The game did horrible when released and OPS were selling them dirt cheap. Now it's an overpriced legend.
#8737 44 days ago
Yup!
I do believe that is the case with the Hobbit. It very likely may be a latent legend!
#8738 44 days ago
Quoted from mbelofsky:
Thanks for sharing as I was interested in this mod. Dio you think the style of it is a natural fit for the game? Cheers.
#8739 44 days ago
Quoted from thewool:
This and the throne mod finish off the game perfectly imho
#8740 38 days ago
Yes. I didn't do many mods on this game besides the game blades and this mod. This mod looks like it came from (or should have come from) the factory. I am very please with it.
I also own LOTR and this same mod would look great in from of the shire loop on the left on the clear plastic in front of it. ( I also own the Doom and Gloom mods from pin worlds on LOTR. I wish I bought pin worlds mods for SW.)
#8741 38 days ago
I absolutely LOVE this game, its going nowhere, permanently bolted and welded down...
#8742 38 days ago
I love it too, but you kinda have to be ready to play it and be up for the challenge. It gets intense and takes a lot out of you. Great game, fantastic code.
#8743 38 days ago
Quoted from KingBW:
This game kicks my ASS. I guess I have mine set up hard because I am constantly getting destroyed... which makes the good games that much more satisfying. Great game!
#8744 38 days ago
Quoted from KingBW:
Well stated. I agree!
#8745 36 days ago
Quoted from KingBW:
Luckily I have 14 games from ones that last a minutes to epic quests (LOTR, Hobbit). I have done a lot better job at following the rules on LOTR than on Hobbit. I know what I have to do but basically happy if I can finish any mode to get credit for this to move forward in the game.
My goal this year is to not buy any more games since I can't seem to part with any right now. So I am trying to play them all to actually learn them better and hopefully become a better player. I really have to think and concentrate on this game. Which is good.
11
#8746 36 days ago
Hobbit is a game you need to set time aside for and totally immerse yourself in it, same with WOZ.
I find playing this game on a lazy Sunday afternoon with a few beers in the fridge to be absolute bliss...
#8749 26 days ago
just joined the club. Criminally underrated and fits perfectly in my small collection. Jacked it up to around 7 incline and it's fast, fun and challenging.
#8750 26 days ago
Quoted from Jeffswack:
7.1 or 7.2 is the sweet spot.
Adjust flippers accordingly.
$ 50.00
6,800
Fort Collins, CO
$ 96.95
$ 12.99
