(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
  • 8,739 posts
  • 550 Pinsiders participating
  • Latest reply 8 hours ago by JonCrox
  • Topic is favorited by 203 Pinsiders
There have been 1,236 images uploaded to this topic. (View topic image gallery).
16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 8739 posts in this topic. You are on page 167 of 175.
#8301 83 days ago
I payed $6700.00 for Smaug in Michigan with Radcals and plastic protectors and blades. I would have payed $6800.00. But it didn't have the updates either. And I see a lot of people asking $7,000.00 for a HUO Stern Prem, not a LE which would be more typically.
#8302 82 days ago
So I have some questions about the ring button.
I know it is used to select your skill shot when gold. I know when red or green it enables you to postpone modes and locks. I know you use it to launch the ball to hit the man targets and load the windlance.
But I discovered it turning purple and hit it. I used to hate hitting it too much so I didnt lose charge for the gollum save light. But i just had a game where it lit purple a LOT. I never noticed that every time you do it, the value goes up by 100 points. I was scoring over 5k a tap at the end of my game.... what triggers this? I feel it is when you're doing something in modes. I just dont know what.
Bonus question: what does it mean when it flashes yellow and it says "light the horn?" I am baffled by this one as well.
#8303 82 days ago
Quoted from Mr_Outlane:
I paid 7400 (shipped) for a gold smaug edition with a few upgrades (protectors, mods), lightly used, if this helps gauge things.
#8304 82 days ago
Quoted from jorant:
Left middle of the screen tells you what the ring button will give you. Purple is good and points.
#8305 82 days ago
Quoted from KingBW:
I know.... I'm asking what the horn does and how do I light the purple ring button. Just switch hits during modes I guess? Still baffled by what "light the horn" means.
#8306 82 days ago
Quoted from jorant:
You mean "light Thorin"? It lights the insert for the Thorin character so that if you hit the captive ball you will collect that character.
#8307 82 days ago
Quoted from jorant:
I should clarify that I think Smaug is definitely worth more than I payed with these mods when compared to Stern LE's. I just had a budget of $6800.00 to spend and got lucky. This pin is a master piece and I think it is ridiculous that it doesn't rate higher than it does. This makes no sense to me other than the fact that it is not a great location game because of the depth. This is also the case with my Alice Cooper. That game is under rated because of the tight shots, but it is super fun and addicting and beautiful. I think these modern high end pins are just too good for the wild now. Stern has the take on the location scene with their Pro's for sure!
#8308 82 days ago
Quoted from jorant:
Quoted from KingBW:
LOL!!
Trying to read that display while playing is a challenge!
#8309 82 days ago
LOL!!
Lol. Well that explains it! Lol. Not sure what that does, either.
Edit: got it now.
#8310 82 days ago
Quoted from Vitty:
Were any of the Black Arrow machines made with a Radcal option?
Friend of mine have a Black Arrow version with Radcal. So yes
#8311 81 days ago
Quoted from Celofane:
I have Radcals on my Pirates LE and they are Stunning...it's equally or a little better than the Direct print cabs on WOZ
#8312 80 days ago
Quoted from jorant:
Switch hits will build the ring. It goes purple when nothing else is available (no mode/lock delay, backstab or light Thorin)
#8313 79 days ago
Just noticed last night while my daughters were playing Hobbit that Smaug's mouth was not moving. He turns and lights up, but just recently the mouth has stopped. I went into the test coils this am and saw all the Smaug tests were in blue. Everything else was gray, and I could test everything except the blue Smaugs in the picture. I removed and reinstalled the USB, and boy was that thing all bent up from the factory. I'm thinking I might have a bad USB cable at this point? Thoughts from the guru's out there? Thanks!
Murphy
#8314 79 days ago
Quoted from MurphyPeoples:
Murphy[quoted image]
Did you ever check the calibration for his min and max mouth movement? There is a specific test menu for just that.
On mine, the stock value for the mouth closed setting was binding the servo. You could hear the servo buzz like crazy crushing his jaws together. Servos do not like to bind. When they bind they pull tons of current and in turn get stupid hot. I think this is why a lot of peoples Smaugs stop talking over time, the servo fries from binding. I was lucky and adjusted mine early in it's life.
Good luck.
#8315 79 days ago
Quoted from Reaper802:
Good luck.
I haven't seen that test on the menu. I'll have to check to see where its at. He has been working perfectly until recently. So hopefully I've caught this early. Any idea why the Smaug Coil Tests in the photo are blue and not working?
#8316 79 days ago
Double. Oops
#8317 78 days ago
Are they disabled (turned off? yes you can do this.) due to the mouth not working?
#8318 78 days ago
I went through the Smaug Head tests. We turns left and right perfectly. Then I ran the mouth test. It would not open and close at all.
Settings were for 100 and 120 like LTG has. I think that is factory.
I'm hoping this is just the USB wire? Anyone else have this issue? Thoughts?
Thank you.
Murph
#8319 78 days ago
Thank you.
Murph
I think the mouth motor is shot. You will probably need to replace it.
#8320 78 days ago
I would take the time to install an inline fuse on these Smaug servos while you're in there so this doesn't happen..
#8321 78 days ago
For me when the jaw stopped working it was a just a wire that had come undone so think basic as well
#8322 78 days ago
Quoted from coz6:
Do you remember which wire? I'm thinking basic too! : )
Thanks Coz6!
#8323 77 days ago
Thank you.
Murph
The mouth stopped working on Smaug a couple of moths ago. During the test I would nudge the upper part and it would move again for a few times then stop. It took it all apart and could not find any lose wires or connections. Called JJP and had them send me a new servo motor. However, since a new motor was on the way and had nothing to lose, I moved the upper part of the mouth with my hand all the way up and back down 10 times in a row, rather quickly, and as strange as that may sound, it has been working ever since. Just telling my primitive method of a last ditch effort.....I can only guess that there was some kind hang up going on inside the servo motor and I can rest comfortably knowing I have a new servo in wait if the current motor gives up the ghost.
#8324 77 days ago
Quoted from Energyspike:
I'm not sure about these servo motors, but motors in general can have bad spots in the windings that can cause this to happen. If it stops on a bad spot, it will not start again until you move it off the bad spot. I have had flakey servos in the past when I was into R/C airplanes.
#8325 77 days ago
A an aside, I still have a lot of left over R/C parts and they have come in handy several times for pinball repair. Those small machine screws and nuts you can't find in hardware stores and other odd ball parts as well. It has saved my ass more than once.
#8326 77 days ago
I moved the upper part of the mouth with my hand all the way up and back down 10 times in a row,.
Not sure about what you mean with the "upper part of the mouth"? Only the lower part moves. But I did what you suggested and moved the jaw slowly several times. Found no binding of the servo. Took the back of the head off and saw the wire bracket that connects from the servo to the jaw in one piece and mounted properly. I plan on ordering a servo motor and an extra USB cable just to have an extra for quick testing.
Thanks !
Murphy
#8327 77 days ago
Thanks !
Murphy
Ahh, you are correct..
#8328 76 days ago
Thanks Coz6!
It was a wire that went into the Molex connector so like I said really basic... But I also have a spare motor because I rushed to those thoughts as well.
#8329 75 days ago
Since we are all going to be under lockdown soon, if not already, how about a competition for best score / accomplishments on Hobbit over the next few weeks?
#8330 74 days ago
Quoted from xsonics2k2:
What did you have in mind...challenge?
15
#8331 73 days ago
The Isolation of Smaug;
#8332 73 days ago
Quoted from punkin:
That's pretty funny. Now Smaug must take some pretty huge shits so I totally understand the need for him to be hoarding that much TP.
#8333 73 days ago
Quoted from pipes:
Plus it will be more valuable than gold soon.
#8334 73 days ago
I wish I could, but they may put us in trailers and work us 12 hr. shifts for 14 days straight and then quarantine us on location for the next two weeks while the next shift does the same. Two 2 man shifts back and fourth (only 4 of us out of 5 volunteered). Sounds bad, but they are willing to pay double time. Big money if it comes to that. We run a natural gas compressor plant. The spice must flow!
What pin to buy next with extra money? Provided great depression II doesn't start.
14
#8335 72 days ago
Killed Smaug for the first time just now.
What an experience that was.
It's going to take me 3 hours to come down off of it.
Don't care what the haters say, what a frigging game that is...
#8336 72 days ago
Quoted from Bendit:
Yep, there’s not much like it in any other games except maybe destroying the ring. Such an amazing game.
#8337 72 days ago
Quoted from Lermods:
True, but melting the witch in woz could possibly top it as well.
#8338 72 days ago
Quoted from konghusker:
True. I killed the witch a couple of times, but only killed Smaug once. They both feel like great accomplishments. Great code writers.
#8339 72 days ago
Yes, but the points awarded for killing Smaug are to low though eh?
#8340 72 days ago
Quoted from Bendit:
Yeah, Horde and DTR are amazing experiences but killing Smaug is on another level. Hitting that last shot perfectly...wow!...there’s just nothing like it.
#8341 72 days ago
Since we are stuck at home, I have been cataloging my 14 pinball machines (Name, serial #, Battery type, Battery Quantity, Last changed, Manual reference and notes).
On page E-14 of the Hobbit manual and page E-11 of the Dialed In! manual, it notes that the battery is CR2032. (I assume this is true with all of their games but only have these two.)
I assumed these batteries would last for 10 years or so. I assumed I would change it with the power off when it died. But the manual states that the battery MUST be changed with the power on (16 steps). My Hobbit is over 4 years old and my Dialed In! is approaching 3 years. So I guess I should follow the directions.
I am posting this just in case someone is not aware of the method to change the batteries.
Both manuals state:
If your game's CPU battery discharges below 3V (or if you remove the battery) while the game is turned off, all BIOS settings will return to factory defaults. As a result, your game will not boot properly the next time you attempt to power it up. In this case, contact JJP technical support for assistance in restoring your CPU BIOS settings and getting your game to successfully boot again.
#8342 71 days ago
Quoted from mbelofsky:
Both manuals state:
Absolutely.
The CMOS settings are reset if you lose battery power.
Always change the computer CMOS battery with the computer on and running.
There is no real hurry to replace this battery.
I have old mainboards 20 years old and the battery is still functioning.
I would think that maintenance-wise the battery might need changing at 7-10 years.
Keep your fingers out of the fan!
-1
#8343 71 days ago
Quoted from pinballinreno:
Absolutely.
Can you unplug the fan to change out the battery?...just to be on the safe side.
#8344 71 days ago
Quoted from Wildbill327:
You mean the one on the motherboard ? And let your processor/CPU heat up and die ?
Man, I wouldn't risk that.
Get a computer nerd to help you if you are worried.
#8345 71 days ago
Quoted from LTG:
It takes that long to switch out a battery?
#8346 71 days ago
If a person has never changed a motherboard battery. Might be nervous about doing it. And is asking about unplugging the fan on the processor/CPU. I have no idea what their plan is, how they'll do it, or how long they will take.
So my advice is to leave the fan plugged in, and get help.
#8347 71 days ago
Quoted from LTG:
I hear you man...you have to make sure you cover your self.
#8348 71 days ago
I would not unplug the fan and risk overheating the cpu, just carefully work around it running.
#8349 71 days ago
It’s not a big deal. I only nicked my fingers three times while changing the battery lol. It makes you jump but doesn’t really hurt.
#8350 70 days ago
Just had a killer game last night. Got to 4th stage of Battle of the 5 Armies. So cool. Unfortunately drained last ball while trying to hit the kill shot on Smaug. He got away...again!
PinWoofer
$ 11.95
$ 29.95
Pinball Photos
