(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
5 years ago
  • 11,158 posts
  • 670 Pinsiders participating
  • Latest reply 12 hours ago by zaphX
  • Topic is favorited by 260 Pinsiders
16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 11,158 posts in this topic. You are on page 144 of 224.
#7151 2 years ago
Quoted from fusion:
The mini book display on my Hobbit stopped working. It lights up when I power up the game so its getting power but it remains black for the rest of the time never displaying any information or video. Any idea what to look for- is this a common issue?
thanks for the help
Check the video connection to it.
Make sure its firmly plugged in.
Check the same cable other end at the computer side. Make sure it is also plugged in firmly.
#7152 2 years ago
Quoted from pinballinreno:
Thanks, I checked both vga connection points (at the monitor and at the cpu) and both are tightly screwed down but still no image I do remember the colors seemed off on the mini display last time it was working.
#7153 2 years ago
Quoted from fusion:
Try a new vga cable
#7154 2 years ago
Quoted from fusion:
Might be a bad display. It happens.
To check the video feed plug the cable into a laptop.
#7155 2 years ago
Or better yet a monitor...
#7156 2 years ago
Anyone have issues with the invisiglass slipping out of the track on the left or right side? It is almost like the glass isnt wide enough. The cabinet appear ok and is not cracked.
#7157 2 years ago
Quoted from MarZ_78:
Yes, some are very loose.
A layer of electrical tape in one corner can firm it up a bit
#7158 2 years ago
Mine is the same. The cabinet is just a smidge too wide. Also the support rails are positioned just a little too wide for the rubber feet to both rest on the lockdown bar mech at the same time. little things but still annoying.
#7159 2 years ago
Quoted from fnosm:
Tons of my games are like this, although ironically not the Hobbit
#7160 2 years ago
Quoted from fusion:
Similar thing happened to me. Color seemed off then intermittent outages. Cabling all checked out. New display hasn’t had a problem - been in longer than the original.
#7161 2 years ago
Jjp sent me free plastic guides that go into glass slots to fill the space. It tightened the glass right up. Mine was so lose, the glass would slip out and scratch inside walls of cabinet when removing or installing glass.
#7162 2 years ago
New place i haven't seen for a stuck ball before. I thought there should have been a ball left during multi but the machine didn't do a search until i tried to start a new game an hour later....
Any one else seen this one? I'm assuming it's come off the ramp...
#7163 2 years ago
i remember early games having this issue.
#7164 2 years ago
There’s an insert that corrects this - if you need one send me a pm
#7165 2 years ago
Does anyone know what the color temperature is for the LED strip in the backbox? I'm guessing it's 6000.
Looking to add lighting on the side and bottom of the backglass art:
amazon.com link »
I should just be able to jumper off the existing strip with these:
amazon.com link »
All and all I should be able to do the whole thing for well under $20.
Thoughts?
#7166 2 years ago
Quoted from Reaper802:
amazon.com link »
amazon.com link »
Thoughts?[quoted image]
You'll need to cut the led strip in 3 pieces. Then you'll need to solder wires connecting the other two pieces to the first one. Then on the end you'll solder another set of wires with the proper female molex to be able to connect to the 12v topper plug. You might want to also consider adding a dimmer switch. For the amount of time and little money you'll save you might as well buy a premade mod. I got one on mine and it's nice.
#7167 2 years ago
Quoted from CLEllison:
Yeah, labor intensive for sure. Here’s ours, $66 shipped, looks really good.
https://lermods.com/products/the-hobbit-woz-pinball-led-strip-translight-side-lights-kit
#7168 2 years ago
Perhaps I'm at an advantage being an electrical engineer but I don't see this as labor extensive at all. In fact it looks pretty simple. For less than $20 in material I could do at least 4 machines. So $5 a machine.
I'll get the stuff ordered up in a few days and do a tutorial on the process. I can probably even put the extras into some cheap kits if anyone is interested.
#7169 2 years ago
I'm game for one. I have the Lermods - mod that lights the trough and back ramp. I used the free, extra outlet. How then will I tie another set into it?
#7170 2 years ago
So on the latest code can't find where to adjust the windlance power I have adjusted the metal guide and it was feeding well updated code a bit ago and lost the setting what am I overlooking thanks
#7171 2 years ago
Quoted from coz6:
The factory default on ver 3.1 should be fine as is.... at least it is for me. The wind lance isnt always reliable/consistent and I suppose it accurately represents using a bow per say. However during the mode where the windlance and 3rd flipper are used to hit the dwarf target, it should fairly regularly shoot the ball into the Kili entrance. Since it's a coil you should be able to find the setting in the coil section of the service menu.
#7172 2 years ago
I guess your time isn't worth much. Shipping, packing, boxes, postage, all kinds of overhead costs, income taxes and a lot more. I can guarantee you nobody is getting rich off mods. Sure you can do it cheaper yourself, just like many things, but if you don’t want to because you don’t have time or don’t have the skill to do it (it requires soldering in tight places sometimes— do it wrong and you cause a short— pinning connectors, etc.), it’s available for sale at relatively low cost from us. There is a tutorial already done on this somewhere, I think for dialed in, search around, it’s there.
#7173 2 years ago
Lermods - I never said a word about your product. I asked about color temp for an LED strip. You jumped in and said it would be "labor intensive", I disagreed. Then somehow this became a topic about the value of my time. Time is priceless, it's can't be bought or stored for a rainy day. I think it's great you are offering a service for owners who want to avoid as much risk as possible and plug and play. I could care less about your profit margins and how you run your business. I will say that this interaction has ensured I will never purchase anything from you.
#7174 2 years ago
it should fairly regularly shoot the ball into the Kili entrance. .
My Windlance has never shot it into the Killi entrance is there a way to adjust it
#7175 2 years ago
Quoted from screaminr:
Mine has always been highly variable. Would love to know if there is something you can do.
#7176 2 years ago
Same here.
On the other hand the left kickback on my DI will make the phone scoop 90% of the time when the guy dude isn’t in the way. So I have to imagine some sort of tweaking will make it happen. Haven’t found that sweet spot yet.
#7177 2 years ago
Bend the end of the right flatrail in the windlance lane
It's easy, maybe remove or loosen the plastic, loosen screw, pry it out slightly, tighten screw.
Bend it in or out as you need.
A little is a lot.
Adjust power as you need also.
In the game it's supposed to be a bit random..
But with a full charge it should go up the right lane and half way to the pops.
My windlance was terrible.
But after 30 mins of adjustment it's now near perfect.
#7178 2 years ago
A little is a lot.
I agree with all you said ^^. My wind lance was terrible out of the box but a minor adjustment much better. My game needed the metal guide bent a bit and power adjusted and now it’s pretty solid.
#7179 2 years ago
A little is a lot.
Thanks , will give it a go , would make killing Smaug a lot easier
#7180 2 years ago
Sorry if I’m being too lazy to search this issue in the forum thread but in playing the game today, the orc pop up started to struggle to operate while I was playing...
I’ve already had to fix/replace a spring on a drop target on the machine so I thought it may be something similar but when I ran a test on the target, the coil really struggled to raise the orc.
Am I in for some major surgery here?
It’s a Smaug Gold edition machine manufactured in July 2016...
Appreciate any guidance.
#7181 2 years ago
Quoted from Ponzie:
First thing is see if it's binding on the hole in the playfield going up. If it moves up and down freely. Next step is to loosen the nut at the bottom of the assembly and the rubber stopper looking thing on the other side of the nut, turn it and raise the mech up a bit. Retighten the nut and try it then.
#7182 2 years ago
Quoted from Ponzie:
I experienced the same problem
Mech triggered, lighted arrow kicks on, light turns on inside mech hole, mech starts to lift but wont come out of the hole, sometimes it moves up and down a quarter of an inch repeatedly as if its trying to pop the rest of the way up but and can’t then tries again. Mech scores a hit, never coming out of the hole.
I got help from JJP customer support. The basic fix was find any places where the mech could be rubbing on the play field, lift the mech up and push it firmly in the opposite direction allowing that the wood gives just enough for the mech to move into a better position. It should be pointed out that you should use gloves as the flap on the mech will cut your hands if you're not very careful.
The height adjustment for the mech worked for my warg that was having trouble popping up as well, I just raised up the black bumper pad that acts as the stop for the mech just a small amount and everything started working perfectly. Apparently the weight of mech slamming down will take this out of adjustment over time. Supper easy fix once you know what to do.
#7184 2 years ago
Looking for input on new rubber set for my hobbit. Titan, white standard rubbers etc.
#7185 2 years ago
Quoted from meSz:
I just did color matched Titan rings on mine. Once I get my ramp situation fixed I'll have lots of photos up. I created a kit on the Titan website.
#7186 2 years ago
Thnx for the post. Pics would be appreciated...what kit did you create, the one on 6/15?
#7187 2 years ago
Quoted from meSz:
Yes 6/15/2019 is the one I built out.
#7188 2 years ago
Quoted from meSz:
I actually did Titan Clear on everything and green on my flippers. The light show on this game is fantastic and clear lets that shine through better than any color.
#7189 2 years ago
Quoted from meSz:
I did green Titans on mine, pics are posted further back in this thread: https://pinside.com/pinball/forum/topic/hobbit-owners-thread/page/114#post-4670113
#7190 2 years ago
Thanks for the post guys!
Quoted from joelbob:
Quoted from KevInBuffalo:
#7191 2 years ago
Sneak peak at my color matched Titan rings. Can't wait to see how they pop with the lights on when the ramp is back in.
20190709_183920 (resized).jpg20190709_183929 (resized).jpg20190709_183942 (resized).jpg20190709_183947 (resized).jpg20190709_183955 (resized).jpg20190709_184003 (resized).jpg20190709_184015 (resized).jpg20190709_184021 (resized).jpg20190709_184026 (resized).jpg20190709_184047 (resized).jpg20190709_184105 (resized).jpg20190709_184123 (resized).jpg
#7192 2 years ago
Sneak peak at my color matched Titan rings. Can't wait to see how they pop with the lights on when the ramp is back in.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Did you shop the machine?
If so was it hard?
I got mine today and am ashamed to admit it has 28,000 games played on it.
Seems to work fine but the 4 posts that light playfield are all not on? Any ideas.
Thanks in advance for any information.
#7193 2 years ago
Quoted from Pinchild:
Spotlights ? 12 volts DC - power at the sockets - if no check for broken wire along the line from spotlights to power source. If 12 Volts is there, check if bulbs are good, if LEDs, if good and facing the right direction.
#7194 2 years ago
If so was it hard?
I'd bet money the LEDs have failed. Those bulbs suck to get out. Use a pair of needle nose pliers. Pull one that's working and put it in one that's not. And as Lloyd said, those are 12v bulbs so make sure you order 12v replacements. And shopping the machine out so sucks. Take my advice and check the back stops on the holes (can do as is by using your fingers). Mine were both stupid loose. When you shop it out, you'll have to pull the ramp which is no great joy to do, but when you do schedule yourself time to install a set of cliffy protectors. If your ramp flaps are curled now is the time to replace them as well. The clear around the holes is very likely to crack and chip. With the ramp out of the way you can clean the backside of the playfield. Ensure the pop bumper wire form gate posts are secure. Mine were super loose.
#7195 2 years ago
If so was it hard?
I had to remove my ramp as it was an early run with the old ramp flaps. Otherwise the machine only has 199 games played when I bought it. It's a little bit of work to get the ramp out, maybe 90 minutes when you do it the first time.
#7196 2 years ago
I have yet to do my ramp flaps. Something I've definitely been avoiding.
#7197 2 years ago
Quoted from konghusker:
I waited until the silver ones actually started cracking from being re-bent so many times.
It's not too bad.
Unplug the opto's under the playfield.
Remove a few screws.
Get smaug out of the way, 4 scews.
Use a tight fitting screwdriver on the tiny screws in the flaps, press firmly.
Don't strip the heads.
It fits pretty tight, a little finesse and slight warping, its out!
Installing the flaps is pretty straightforward.
If you can, use the press rivets instead of the pop ones, they last longer but either will work.
Working slowly with a lot of distractions took me 45 mins.
This included cleaning and waxing underneath.
#7198 2 years ago
It's not too bad.
IIRC you also have to remove both hobbit trails. Take pictures and make note where your optos plug into the board.
#7199 2 years ago
I'm in the market for a rivet press to do this sort of work, any suggestions? I'm in Canada, but can wait on an online order...
#7200 2 years ago
Hey got a question thinking about making a trade for a hobbit is there something I should look for or a year that it was built to see any problems
