New! Dark mode!
(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
  • 9,153 posts - Hot topic!
  • 577 Pinsiders participating
  • Latest reply 1 hour ago by WizardsCastle
  • Topic is favorited by 221 Pinsiders
There have been 1,292 images uploaded to this topic. (View topic image gallery).
16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 9153 posts in this topic. You are on page 124 of 184.
#6151 1 year ago
Quoted from LTG:
I know there are different kinds of stainless steel. I didn't know any could rust. Thank you.
I worked in the metal fab industry for 10 years. Yep! You can't always trust the certs or that the alloy is not contaminated. Totally depends on the manufacturer of course. We had problems with 304 SS from China rusting. It is also possible to contaminate the stainless steel during fabrication by mixing cutting or grinding tools used on mild steel previously (which is probably the case here).
#6152 1 year ago
After the 3.0 update my upper left flash light is continuously flashing in attract mode, is this the way it should be or Is there any fix that I need to do?, See video of the light in attract mode.
#6153 1 year ago
Quoted from Jireteg:
No it should not do that - loose connection or failing bulb swap bulbs and see if behavior changes
#6154 1 year ago
Quoted from coz6:
Thanks, It is actually more than one, but when I looked now more closely 2 of the 4 spotlight bulbs were black, can this be the problem. Have new bulbs coming and are going to test with all 4 working. Connections is ok. When I test these lights in the led test they blink slowly both when testing solid light and flashing.
When I move the working ones on the left side to the right side it is the same flashing.
#6155 1 year ago
All I can say is my game does not flash at all these to my knowledge are on or off. Something is off but I can't be of much help.
#6156 1 year ago
Hello,
I have 2 little troubles with my Hobbit. Maybe someone could give me a tips on how to solve them
1) Since a few days, my Orc randomly seems to hesitate before popping up. (see at 0:04 & 0:13)
https://1drv.ms/v/s!Au8iWRzg08HDpE5MkuFtMOQW72_T
2) This one happens less often and it started exactly since I've upgraded to 3.0 1 month ago. At the beginning of a ball, as soon as the ball arrive in the launcher, the skillshot is selected automatically and the autolaunch kick the ball immediately. Any other people have seen this after upgrading to 3.0?
#6157 1 year ago
Quoted from Jgaltr56:
That's right. Rust can become visible when the manufacturer (typically Chinese) cuts corners and doesn't use the minimum amount of Chromium needed, or if the alloy has too many impurities, interfering with the film that prevents rust from forming on the top surface.
#6158 1 year ago
Quoted from ChrisLIX:
I think I may recall having seen something about checking your switch matrix - seeing if anything is triggered on the playfield when it shouldn't be. Not sure about this but I seem to recall that certain switch triggers (shorted? misadjusted?) can cause this behavior. I'd suspect the game may mistakenly think something is in play and launch the ball for you.
#6159 1 year ago
Small problem with my Orc head topper(the flat piece on top of the pop up that lays flat when he closes). The topper piece most of the time is not closing all of the way down when the orc goes down, it remains open a few millimeters, but enough where the ball won't roll over the spot smoothly and will damage it.
I'm hoping someone on here has experience with this and how to fix it. Not sure if it is a problem with the spring needing adjustment or if there is a broken part. Any help is greatly appreciated.
#6160 1 year ago
Quoted from elf70:
Hello,
It happened 1 time yesterday. Here's the event log that show exactly the scenario. Looks like an ELF Skillshot but I have check the matrix switches and I never saw an unattended switch activation...
Will wait the next time to see if it happens again on ELF skillshot autoselection or if it's random with any SS.
#6161 1 year ago
Hello,
I have a similar issue with mine on the goblin. Curious to see what people suggest here for a fix...
#6162 1 year ago
Quoted from Jcaurnend:
Quoted from joelbob:
Lower the screw/rubber stopper at the bottom of the assembly.
#6163 1 year ago
Quoted from LTG:
LTG, same solution for 2 differents problem? One is refering to the monster cover not falling flush with the playfield and the other one is refering only to the monster hesitating to popping up.
Just want to be sure before playing with that thx
#6164 1 year ago
Lower the plunger for cover, raise the plunger for popping up better.
#6165 1 year ago
My left VUK more often than not takes two and sometimes three attempts to successfully kick the ball up through the wire form. On failed attempts it will kick up about halfway then fall back below playfield. Anyone know how to fix this? Thanks
#6166 1 year ago
Quoted from Brog319:
Raise the power 1 or 2 in the settings, for that coil.
#6167 1 year ago
Quoted from pinballinreno:
Thanks, I’ll try that. I just assumed it wasn’t a power issue because it does eventually push it back onto playfield. Thought it might be some sort of alignment issue. Will try raising power first and see what happens.
#6168 1 year ago
Can anyone tell me how to get to “There and back again”?
#6169 1 year ago
Quoted from NightTrain:
YouTube it. Chuckwart of stdm did it. Pretty much just play every mode. Only have to beat 3 for the 3 wizard modes.
#6170 1 year ago
Quoted from Jon9508:
Oh nice. That’s a cake walk! Lol!
#6171 1 year ago
How about barrel kicks? I never seem to get any. How do you collect?
#6172 1 year ago
Check under the PF that the kicker is aligned properly too - some people have had issues where it’s slipped a little bit and the clearance for the ball is really tight. Realigning it will open it up better
#6173 1 year ago
Quoted from Rdoyle1978:
Will do, thanks
#6174 1 year ago
Whats a Smaug version worth nowadays? Probably 2 dozen plays on it.
#6175 1 year ago
Quoted from PACMAN:
I think HUO Smaugs top out at 7K. Maybe with plays that low 7,200 ish.
I have seen them as low as 6500 if the owner is trying to sell it as quick as possible. So 6500 to 7200 range depending on condition and play count. NIB is around 8.5 to 9K
#6176 1 year ago
I am considering Hobbit and Dialed In for my next pin. I have found a lot of discussion about comparison of these two pins, but it was all pre 3.0. So, for those of you in this thread that have 3.0 hobbit experience and Dialed In experience, what would you choose and why? This would be my 2nd pin for my collection, I currently own JJP POTC LE. (which I love)
#6177 1 year ago
Quoted from f3honda4me:
Hobbit and Dialed In are very different games.
I would put a few games on both and then decide.
#6178 1 year ago
I am considering Hobbit and Dialed In for my next pin. [...] This would be my 2nd pin for my collection, I currently own JJP POTC LE.
I have Hobbit, Dialed In and POTC. Compared to POTC I find Hobbit to feel the most similar in play style, so for variety's sake in a small collection I would recommend Dialed In.
#6179 1 year ago
I can't tell you much about Dialed In (only played it a handful of times), but I can say that Hobbit is incredible. I was recently looking to sell mine but I just couldn't once I played 3.0. The game has great depth and is a fun journey to play.
I'm actually on the hunt for a Dialed In and POTC....and WOZ (again). JJP pins are just so far and above others, it's hard for me to buy a Stern or a CGC remake. $8000 for a MBr when you can buy a POTC for $1500 more? Seems like an easy choice.
Anywho....if it were my choice, I would take a Hobbit over Dialed In.
#6180 1 year ago
I love DI and plan to buy one someday. I wouldn’t trade my Hobbit for one though.
#6181 1 year ago
I have both - and.. yeah, they are very different games. If you like Pat Lawlor's games where they are fun to shoot, have lots of combos, and are mode-based, but not terribly deep - then that's DI. Awesome, very fun, amazing game. DI is PACKED with mechs and the type of mechanical, physical stuff that sets pinball apart from video games.
Hobbit is a journey - I don't mean a slog, where you're chopping wood - but it is *very* immersive. Dialed In is similar to playing a really fun video game (lots of video game influence with the bosses, health meters, etc) - while the Hobbit feels like you are IN the game.
It has 30-something modes, which is at least double the next game (Houdini), AFAIK. THey are all fun, and they are all really clever. The modes which come available a bit later on in the game use the monster mechs extra effectively: when you are in a battle, you are bashing into them to fight off the attack, whilst still trying to make regular shots. Other times the monsters are used as barriers to change the playfield and force you to re-think your available shots. AND THEN there is this diverter which comes out of nowhere on the ramps, and makes the ball come flying back at you in a very tight turn (similar to the Star Wars Tie Fighter shot [i think]). That is awesome when that happens.
Add to that actual callouts from the game, a Gandalf sound-alike, tons of actual music from the films... and a bunch of very fun wizard modes. Oh, and killing Smaug. Not even the Master Magician mode, nor is it the "end" of the game, but it is amazing when you do it.
Previous criticisms of the game included that it would get super long (this was true), the multiballs were coming up too often (also true), the playfield is "wide open" (I disagree on this because of the phenomenal use of the monster mechs, and the fact that a lot of the game mechs are placed at the far outer edges of the PF but still do their jobs just as well as if they were in the middle)... and it generally just wasn't as fun as it probably could be. I agreed with that after a while. UNTIL 3.0 came out. Holy crap.
I sold my Hobbit last year - just bought it back. And I am now getting ready to sell DI (which I really enjoy, just not *quite* as much). Hope that helps.
#6182 1 year ago
Thanks, I have played both and like both. But I always enjoy hearing others thoughts as well. Sometimes I overthink it, and it helps to hear what others experienced!
This is VERY helpful thank you. For me, DI feels very fun, the shots are very satisfying, a lot going on, and while I originally hated the theme, I now really like it. It's super quirky and fun. I agree hobbit to me felt much deeper in ruleset and mode etc. POTC is great, but can be very mean on ball drains. It also is very multi ball heavy, and the chapters are nice in that they spread out shots over the field.
For me I'd like my 2nd game to be "different" from POTC. Ideally, something that is a bit "nicer" on the ball drains (helps with kids and wife!), so longer ball times is a plus. I'd also like something that is less multi ball, with more "shooter" fun where you have to hit certain things. There is no doubt the theme integration on hobbit is phenomenal. Did 3.0 decrease the amount of multiballs? If not I'd fear it is too similar to POTC in that regard. Hobbit seems like it would be an "adventure" with lots of specific shots needed to progress, where as you said, DI is more about the modes and the very satisfying shots you can make, along with the great quirky theme.
So, you can see why I'm torn! I want a game that is different than POTC, a change of pace, with a bit longer ball times.
#6183 1 year ago
Ive got the solution. Sell me your pirates and then you can buy Hobbit AND Dialed In!
#6184 1 year ago
Hah unfortunately that doesn't work out from a $$$ standpoint :p
#6185 1 year ago
One of the best changes to the Hobbit was a setting change that made it so Smaug Multiball couldn't be stacked with Beast multiball, saved a lot on the chaos of multiball after multiball. Multiball comes when you want it now.
#6186 1 year ago
Quoted from Rondogg:
Excellent!!
I know this pin has music from the movies, does anyone know if it has the “misty mountains cold” song at any point or during any mode? It’s my wife’s favorite.
#6187 1 year ago
Hobbit is just getting better and better. I just played a great game only scored 800K but the modes are so much more to fun to play and it is very easy to understand what to shoot for. The sounds ,lights and screen footage are second to none.
#6188 1 year ago
I couldn’t agree more. I love that setting. I hated beast and Smaug stacking. Really took away from both of them.
#6189 1 year ago
The family said the Hobbit looked lonely without a topper, so they surprised me with this!
#6190 1 year ago
Hm, I was going to say get DI until you said longer ball times. Hobbit naturally has longer ball times because of the widebody playfield. I haven't played POTC enough to really get to know its shots and ball times, but it kinda sounds like you should go for DI. Really hard call though
#6191 1 year ago
Quoted from Crile1:
The family said the Hobbit looked lonely without a topper, so they surprised me with this![quoted image]
Consider yourself extraordinarily lucky I have never had this happen ever in my life. My wife once forgot to get me something for christmas until the day before, and only because my son reminded her. LOL
#6192 1 year ago
Quoted from sulli10:
seconded. I also have a Houdini which has a lot of similarities to Hobbit in this way - the modes are REALLY fun, and complicated but not out of control - however Houdini is still really rough around the edges. There is all this complaining about the shots being "bad geometry" (which is complete BS), but it is true they need a lot of work on the animations and transitions, and whole package. Just tweaks, mind you, it will happen. Since Hobbit is another whole level now, it's not fair to compare...
#6193 1 year ago
I have the hobbit and love it, bought a DI and sold it after 2 months. DI is a great shooter and the shots are smooth and all the modes are fun to play through. The reason why I sold it was something was missing compared to the Hobbit, just didn’t have that feeling like I was in the game. I put over 500 games on DI and was ready to move on but the game was fun, shot good, just was missing that wow factor. On a side note I just bought WOZ.
#6194 1 year ago
The new 3.0 code on my THLE has completely changed the game for me. It truly plays like you’re in the movie. And the new voiceover callouts have helped me a ton to keep me focused because this is one of those games that requires guidance, focus and patience. Such a phenomenal game and so proud of what the JJP team has done to make this game what it has become. Hope they are proud, too.
#6196 1 year ago
I owned and sold WOZ. Still love the game but we decided to try other pins. For me, Dialed In is a solid game to play on location. I don't want to own it because I don't like the generic theme. Someday, I'll own a Hobbit, and it'll be a keeper for life. Probably put over 100 games on it on location, love it. The theme is awesome, probably the best overall theme integration of any pin in existence.
#6197 1 year ago
Quoted from coz6:
Fixed, It was due to 2 of 4 bulbs that we’re dead, with new bulbs they are lit solid and not flashing.
#6198 1 year ago
Joined the club and Hobbit will be my 2nd pin. Arrives tomorrow!
#6199 1 year ago
That's awesome! We play our hobbit most, second only to our Metallica. It's such a great game. You'll love it.
#6200 1 year ago
Did you buy a new one from a distributor?
$ 49.95
Pin Stadium Pinball Mods
Springdale, UT
$ 96.95
$ 499.95
7,750
Sale Pending!
Smithtown, NY
$ 349.95
