(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
  • 7,923 posts
  • 519 Pinsiders participating
  • Latest reply 3 hours ago by konghusker
  • Topic is favorited by 192 Pinsiders
There have been 1,152 images uploaded to this topic. (View topic image gallery).
16 key posts have been marked in this topic (Show topic index)
There are 7923 posts in this topic. You are on page 110 of 159.
#5451 1 year ago
Quoted from check_switch_26:
You are looking for differences that are not there. Only four states are indicated on the hex icons:
unqualified
qualified
qualified and selected
played
--Ted
Hey Ted, so 'played' is not differentiated from 'completed'?
I suppose completing modes has no bearing on the game except for scoring, so maybe doesn't need to be identified. I can't remember if you need to complete modes or just play them as an alternative way to qualify for an Arkenstone mode.
Some time ago did you also say you were going to consider adding an 'option' to stop Beast MB from starting during an active mode? The amount of times I'm ace-ing a mode only to have Beast MB start and subsequently block critical shots, thus setting me back in Arkenstone qualification progress. Thanks for thinking about this one.
#5452 1 year ago
Stepped up to my game tonight a bit miffled as I still hadn't managed to kill Smaug after about 1.5 years of ownership...
First two balls drained quick but I soldiered on. The third ball seemed enchanted and I quickly won two extra balls. Played Smaug MB once and got pretty far, then Into the Fire. Managed to play Smaug MB a second time and I looked up to see I was on the kill shot! Loaded up the right flipper and boom! So happy to see the 'Dragon Slayer' title at long last, and a hair away from BOTFA which I've never seen yet.
Amazing game.
#5453 1 year ago
Quoted from thewool:
Amazing game.
I have only done it once but it is SO cool! Not sure there is another game this amazing. Well... Dialed In
#5454 1 year ago
The only place where completing a mode is required is to spot one of the Arkenstone jewels in order to qualify an Arkenstone Mode. The "Book Mode" jewel is here:arkshard (resized).jpg
As you note, completion percentage affects scoring, and obviously "complete" - 100% - is the best result.
--Ted
#5455 1 year ago
unqualified
qualified
played
--Ted
I thought you could go back and complete a mode you hadn't finished ,still learning the game . great pin Ted
#5456 1 year ago
Quoted from screaminr:
No. There’s no way to do that. So if the mode is lit up in color, you’ve played or completed it. Since that is all that matters for getting to TABA, I don’t see all the color coding as necessary.
#5457 1 year ago
Quoted from chuckwurt:
Would there be any negatives to going back to a mode. the way it is now it's good it makes you play all the different modes but on the other hand it could be good to be able to go back and complete modes.
#5458 1 year ago
Then you could exploit the scoring in the arkanstone modes. You could just keep playing a 4-5 Star mode until you’re done with it, then blow the game up on the arkanstone mode.
#5459 1 year ago
Fair point
#5460 1 year ago
So what happens when you have started all the modes, and want to start another? Is that when you can start TABA - and after that all the modes reset? Or do all the ones you didn’t complete reset?
#5461 1 year ago
Quoted from Goronic:
So what happens when you have started all the modes, and want to start another? Do you then to TABA and after that all the modes reset? Or do all the ones you didn’t finish reset?
* Before the code update * I did that once and they all reset after a Arkenstone mode. My ego was deflated when that happened - I had to start over. Just guessing that if the book modes are the qualifiers for Arkenstone, you just wont get anymore book modes until the Arkenstone is played. Also guessing that TABA would play right after the last mode times out or is completed, which would be before you shoot the Arkenstone shot/hole. (???) [Speculating]
#5462 1 year ago
Current code: Once you have played them all, you hit either hole to start TABA. After that, all Modes reset so you can play them again.
All other game progress stays.
#5463 1 year ago
You can always see which modes you completed by going to the new progress screens by cradling the ball for a few seconds.
And yes, the two holes flash white when all modes have been played and TABA is ready.
#5464 1 year ago
Quoted from Rondogg:
So you can do TABA before ITF right?
#5465 1 year ago
Yes. Only requirement for TABA is playing every mode.
#5466 1 year ago
The only place where completing a mode is required is to spot one of the Arkenstone jewels in order to qualify an Arkenstone Mode. The "Book Mode" jewel is here:[quoted image]
--Ted
Thanks for that Ted. I was getting confused by this, is this saying that if I complete all modes in a specific qualifier i.e. all the MAN modes, then I qualify for an Arkenstone mode and skip the 5 jewel requirements? :
- Added award for playing all Book Modes for a given qualfier; award is configurable for points (default) or spotting an Arkenstone task
Also did you say there was an option coming to stop Beast MB from starting during an active mode? i thought I read this somewhere. Thanks.
#5467 1 year ago
Hi,
can someone tell me the dimensions of the cabinet high? (front and rear)? Without Backbox and legs.
Thanx
#5468 1 year ago
All new software related questions are answered here.
https://pinside.com/pinball/forum/topic/details-new-hobbit-code
#5469 1 year ago
Quoted from Simbl:
Hi,
Thanx
25 inches wide 52 inches long 24 inches high at rear and 16 and a half at front , plunger extra 2 and a half inches
#5470 1 year ago
#5471 1 year ago
Thanks for re-posting that; I had completely forgotten you can switch book modes
For a moment after hitting the ramp!
#5472 1 year ago
I'm sure this has been answered before, but feel too lazy to try and find it.
Where does the game display the number of extra balls you have saved up during your game? Is that a setting I have to turn on?
I never know how many are in reserve.
Thanks.....
#5473 1 year ago
Quoted from XpertDBA:
Thanks.....
Doesn’t it show it real big on the main screen before you
Plunge?
#5474 1 year ago
Thanks.....
Balls in reserve setting.
#5475 1 year ago
Quoted from Lermods:
Where exactly is this located in the menus? I couldn't find it.
#5476 1 year ago
I love knowing how many balls you have to go. I find it really handy because you can have more balls before you know it especially after multiball ,and if you want to go for something risky it's good to know how many balls you have left ,if anything it should be an option to turn it off . I think it should be there in every mode.
#5477 1 year ago
Thanks so much. One further question on this.....I turned it on and see where it's displaying on the screen. If on the first ball, I get 2 extra balls will it show all of those balls or just max out at 3 on the screen? What if I was to get really lucky and get 3 or 4 extra balls on the 1st ball. Will it show all of those? What's the maximum it displays on the screen?
#5478 1 year ago
The number will show the 3 balls + add any extra balls you earn. There is a maximum extra balls setting in the menu. I think the default setting is a maximum of 5 extra balls. Someone will correct me if I'm wrong.
#5479 1 year ago
Quoted from KingBW:
No, didn't mean the setting for how many max. extra balls you could get. Was wondering what the number of max. balls displayed is if you had lots of extra balls saved up, under the Balls in Reserve setting.
#5480 1 year ago
Once you get past three balls it will show it like this
#5481 1 year ago
Ah cool......thanks for the image. That answered my question.
#5482 1 year ago
This is for screaminr from the question in the JJPOTC club thread …
For connecting TH to a external sub, I used what Pinnovators recommended and it works great. First I bought an RCA splitter for the sub connection at the back of the box from Amazon, then a RCA to STEREO 3.5mm adapter at monoprice:
https://www.monoprice.com/product?p_id=7241
then used the Pinnovators 3.5mm stereo cable and routed that out through the back under a small access plate (that no one knows what it is for) that has the 4 screws (just pinched the wire casing a touch with it so that it wouldn't get accidentally pulled), then to the Pinnovators sub splitter.
I had bought 5 of those monoprice adapters because they were cheap but had questionable reviews - all 5 worked. Pinnovators said that they never had or heard of a problem with them. Their theory was that it was best to have the sound coming from both a RH and LH audio channel. I have that setup with the adapters for both my WOZ and TH and the sound is great.
If nothing else it can give you an idea of what to do. I see that the monoprice RCA to 3.5 stereo is out of stock until 10/25, so if you want one I will bring one to Expo with me and give it to you for 50 cents. I don't have another extra RCA splitter though. Let me know ...
#5483 1 year ago
Quoted from KingBW:
Thank you so much for taking the time and effort to explain everything so clearly , really appreciate it . With The Hobbit having such a good sound setup how much difference does the extra sub make .
#5484 1 year ago
I had an external 300W sub hooked up to my Hobbit but it's to much. The sub used in the pin is also a 300W version. Not worth it (in my opinion)
#5485 1 year ago
I guess that it depends on your taste and preferences. I like the external sub as it gives you better adjustments to accentuate the bass like a movie theater. You can possibly do some of that with the speaker in the pin, but then you are rattling the pin more when you are looking for the sound. When the sound levels increase for the intensity of the various modes is when the difference is most prevalent. Just my opinion. The existing JJP sound systems are great for pins either way.
#5486 1 year ago
Quoted from KingBW:
With how good jjp sound is ,it's probably over the top but I like over the top and will give it a go down the track . once again thank you for your help and advice .
#5488 1 year ago
Ok, so can someone tell me.
How many waves are there in the mini-Wizard modes to actually defeat them? I get Into the Fire on most games, and I fight through 3 or 4 waves, but usually I can't get past that 4th wave. Is that the last one, and you defeat it if you get through it? Or is there a 5th or 6th wave (or even more)?
Same for Barrel Escape and BOTFA....is there someplace that documents exactly what must be done to fully complete those?
Thanks - Robert
16
#5489 1 year ago
Joined the club yesterday. I’m going on an adventure!
-2
#5490 1 year ago
Yet Dialed In has been forgotten about.
#5491 1 year ago
Quoted from TomGWI:
You’ve not been keeping up - new code for DI is being streamed on Monday!
#5492 1 year ago
Quoted from Rdoyle1978:
And tested at Expo, and released soon after.
#5493 1 year ago
Quoted from KevInBuffalo:
Good choice. Jjp's all lineup so beautiful together.
#5494 1 year ago
Just missing a WOZ. I’m going to add a DI soon hope it’s a good challenge.
#5495 1 year ago
Going to stream some of the new 2.97 code tonight, 8 p.m. Eastern: http://www.twitch.tv/buffalopinball
#5496 1 year ago
Has the MSRP price come down on the hobbit since back when it was first revealed
#5497 1 year ago
Cool.
#5498 1 year ago
Quoted from Jpp718:
No but mint used HUO is readily available at $6500-$7000. Hands down the best bang for the buck pinball experience on the market today.
#5499 1 year ago
Quoted from Dkjimbo:
So NIB is still going to run you 8500$
#5500 1 year ago
Quoted from Jpp718:
yes, according to the agreements that the distributors and JJP have with each other.
Andover, MA
7,000
Evansville, IN
$ 27.00
Pinball Forever
7,000
Flagstaff, AZ
PinWoofer
