(Topic ID: 158133)
HOBBIT LE - Lights not working on playfield.
By RichieWrench
6 years ago
  • 21 posts
  • 15 Pinsiders participating
  • Latest reply 1 year ago by Pin_-_K
#1 6 years ago
I just got my Hobbit LE and the plunger is very weak ...not not work it looks like it is rubbing on something. But the bigger issue is that I do not have any lights showing on the playfield. Everything else is working as far as LCD screen. but none of lights are working on playfield. Can some give me some insight on this or has this happen to someone out there. I am not good tech...I am just a plumber...But i will try. Just seeing if anyone might be able to help.
#2 6 years ago
Check all the connectors to make sure nothing came loose in shipping including at the circuit boards.
#3 6 years ago
Is that all underneath...Remember...Plumber....lol. I do have a tech guy that can look at it on Tuesday. Just getting asking for some advance help to see if it is simple.
#4 6 years ago
Sorry to hear this... Has to be something loose underneath..
#5 6 years ago
Take glass off, lift playfield up and remove the metal cover revealing all electronics. Check for loose wires. If nothing is obvious, I'm sure Lloyd or someone with better hobbit experience will chime in shortly. Hate to hear your bad experience so far.good luck
#6 6 years ago
The LEDs plug into boards fastened to the bottom of the playfield, start there and be sure connectors are on tight. Then look carefully around the rear of the metal box with all the boards, behind it and along side. Something came unplugged.
#7 6 years ago
If you can't fix it, you should probably sell it (to me).
#8 6 years ago
Not good that they would let it leave the factory like that. Hopefully it is just a connector issue.
#9 6 years ago
Quoted from musketd:
The game went from eastern PA to Illinois down interstates that have not been repaired from winter. Ship happens.
#10 6 years ago
Want to say thank you to all for your help and Thanks to Frank @ JJP. I actually fixed it on my own with everyone help and it was a loose cable that plugs into the control board under the playfield. Frank is going to help on the other items that need to be fixed. Most are minor but what was important to me was that He was quick on the response ...VERY QUICK. Thanks to all for the comments -- This is best site for help for overall Pinball
#11 6 years ago
Just received my Hobbit SE, everything seems to work except the playfield and ramp LEDs. I tried checking the connectors on the outside of the control board as well as several others that I thought may be more likely to have come loose.
Did you have to actually open up the control board and plug something back in? Which cable was it? I'm hoping we had the same one come unplugged, still no luck finding it.
#12 6 years ago
Power off the game.
Examine all of the connectors coming out of the back of the big silver box (computer) under the playfield, use a flashlight if neccessary.
Check to see if any are disconnected or loose (tug on them a little?) Maybe unplug and re-plug them in one by one.
Carefully examine the wiring harness on the playfield itself, from the bottom to the top, gently comb through it with your finger tips, see if anything seems disconnected.
#13 6 years ago
Turns out the problem was a micro usb cable that had come unplugged from the central circuit board with all of the grey led cables going into (go figure). It was hanging 3/4 of the way and I had missed it since I was focusing on tracing all of the colorful cables and not the plain black cable.
Thanks for your help LTG and Pinballinreno
#14 6 years ago
Great news, glad you got it sorted out!
#15 6 years ago
Quoted from goldant:
Same thing happened to me a week or so ago. Easy fix.
#16 6 years ago
nothing better than tech supporting yourself and being able to fix the problem on your own. More and more on pinside need to start spending less time modding and more time learning how their games work. Kudos and a repair well done.
#17 6 years ago
Quoted from CaptainNeo:
I called tech support...
#18 6 years ago
but you still fixed it yourself. That's the difference.
2 years later
#19 4 years ago
Here are a few photos of the micro-usb location for the next person.
And on a personal note, the engineering underneath this machine is both awe-inspiring and terrifying.
2019-02-28_084830 (resized).pngIMG_3410 (resized).JPG2019-02-28_085348 (resized).png
2 years later
#20 1 year ago
Thank you for the photos. Just had same problem on a trade
#21 1 year ago
Just had the same thing happen to our
Hobbit-Smaug !
Had to replace the MAN Drop Target Bank on ours as ALL 3 Target Ledges were either broken completely off or falling apart from the Rivets being Over-Pressed cracking the DT Target Ledges - the M & A DT's wouldn't stay up when resetting & the N was getting pretty iffy.
Anyhow when I turned the Game back on NO PF Lights or GI Lights, all that was on was the 4 Spot Lights.
Mini USB looked fine but barely pushed on it and LIGHTS !
JJP already had Cable Ties on it, apparently they weren't snug enough as what you see sticking out was how much I was able to tighten them by.
IMG_20210919_152806498_HDR (resized).jpgIMG_20210919_152819178_HDR (resized).jpg
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
$ 399.95
Pin Stadium Pinball Mods
Led
$ 259.99
Toppers
This page was printed from https://pinside.com/pinball/forum/topic/hobbit-le-lights-not-working-on-playfield and we tried optimising it for printing. Some page elements may have been deliberately hidden.
