The board didn't have 3.3v so 1st thing I did was replace the 3.3 voltage regulator. After that the board booted. When tried the board in the game, there was no sound and the video on the DMD was garbled only if you have a color DMD, with a regular LED DMD would not show video.
The sound part was easy, there is only 2 chips involved in the output other than the CPU, the DAC chip was super hot. Voltages going to the chip were right. so I replaced it and sound came back.
For the video part, I measured the signals with the oscilloscope coming from the Xilinx chip and they were fine. The output from the HC244 seemed also fine but there was a difference in one of the outputs, so I replaced the chip and fixed the video output.
Then game wasn't saving the time, so I figured the RTC chip was bad.
And lastly, the ferrite bead on L1 was blown.
So, the short/over voltage propagated through the board. At first, I suspected that one of the Xilinx chips faulty which is a bummer because you can only get them from Stern.
BTW, I do not only repair Surface mount boards, I do all kinds, mostly from WPC era and up.
