You’ll be fine. It increases the power a bit but it’s not Life altering.
I did it in mine and it helped the flippers but it doesn’t create airballs or anything.
Quoted from currieddog:Why the suggestion?
He said it would play faster and hit harder.
Quoted from Mitch:give it a good wax and rebuild the flippers if they arnt strong enough. no need to high tap.
Everything is rebuilt and waxed. I'm curious to try it.
Quoted from 0geist0:Everything is rebuilt and waxed. I'm curious to try it.
Then go for it if you don't like it you can always switch it back. Let us know what you think.
If I want an em to play fast I pitch it until the ball returns to the flippers at the speed I like, then if the flippers can't get the ball back to the top put in hotter coils on or high tap. If the game has a spinner then the proper pitch also depends on the way it hits that. Personally I don't care for the slamming of the pops and kickers on high tap or the flippers usually either. Also before playing any new old game always at least replace the flipper bushings, sleeves and verify proper bat clearance and condition. If your playfield is stable with level inserts and waxed you will cause little harm but if not you will wear it much faster.
This page was printed from https://pinside.com/pinball/forum/topic/high-tap and we tried optimising it for printing. Some page elements may have been deliberately hidden.
