Quoted from johnwartjr:The P1 and P2 displays may be a CPU problem. I notice the same segments are out on P1 and P2.
I hope you are wrong!!!! So when I purchase the machine the P4 numeric display was completely out.. The P3 numeric display worked but kind of scrambled like its on its way out.. The P1 and P2 alpha numerical displays had segments out and looked to have a good amount of burn in..
The pin came with a newly purchase master display board and numeric display for P4. I put in the new display in P4 and the new master display board... Same issues with P1 - P3 and P4 was crystal clear like you would hope for a new display... I swapped P3 and P4 and still had an issue with the P4 that had been in P3...
I wiggled and unplugged and re plugged all the connectors but still no luck with P1 and P2... Also had a segment out on credit display... With the burn in on the existing displays I gambled that they were display issues and just bought the XPIN replacement... Figured it would be easier than hunted down the two alpha numerical displays, numeric display and credit display...
I hope I'm right... we'll find out when they get here.
