High Speed - warm up needed for sound fx - FIXED
By Stormtrooper
4 months ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 3 months ago by GRUMPY
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
    #1 4 months ago
    Purchased a high speed with sound issues. Got the sound going by reflowing solder on some connectors and fixinna bad trace but the sound fx dont start until the game has been left on for 20 minutes and then they work perfect. If the game is shut off and back on immediately they still work. If the game is left off for 20 mins they will need to "warm up" again.
    Any ideas ?
    #2 4 months ago
    If I were a betting man, I'd probably say that you'll want to re-cap the sound board. Electrolytic capacitors are sensitive to that kind of thing, and when they're failing, the additional heat probably kicks them into line to start working again.
    #3 4 months ago
    My understanding is that the sound board controls only the music which is working fine and the sound fx are located in the sound chips on the mpu. Would the same apply to caps on the mpu then ? Bad caps on the mpu would satisfy why music works properly and sound fx don't.
    Can the capacitors be tested onboard ?
    #4 4 months ago
    Also whats the voltages coming from the power supply when cold/ hot. Has the power supply been recapped? You could also have a cracked solder joint on the 12/-12 header pins of on the power supply or 1J17 of the Cpu board.
    #5 4 months ago
    Voltages from the power supple are all good and the same when hot/cold. Will check 1J17 header pins tonight. Thx
    #6 4 months ago
    All electrolytic capacitors on mpu have been replaced and 1J17 repinned. No changes, same problem. Any other suggestions ?
    #7 4 months ago
    Quoted from Stormtrooper:
    You can let it warm up and put it in sound test, lock it on a call out that stops working when cold. Take a can of air upside down and spray it on a component like U-4 op amp. See if you lose the sound.
    #8 3 months ago
    So a big thanks to Grumpy for the idea. I let it warm up and get to a fully working state and then placed a plastic icepack on each component for 20 sec. when I did it to the sound processor IC the sound fx cut out. Remove the icepack and they came back after 5 mins. Repeat several times and the same result.
    So I got a new MC6802P and put it in and it works perfect without warming up.
    I cant say that I would have ever thought of an idea like this. Dont know if its your idea originally or you heard it somewhere else but its pretty outside the box and genius and saved me when I was teally stuck. Now I'm enjoying my high speed as it should be.
    Thanks !
    #9 3 months ago
    $ 30.99
    Lee's Parts
    $ 65.00
    Flip N Out Pinball
    Apparel - Unisex
    Pinball Wheezer
    $ 6.00
    Various Other Swag
    Double Danger Pinball
    $ 24.50
    $ 159.99
    $ 99.99
    $ 194.99
    $ 8,500.00
    PinballSTAR Amusements
    $ 7,999.00
    Flip N Out Pinball
    $ 69.99
    $ 69.99
    $ 24.50
    Medisinyl Mods
    $ 229.99
    $ 16.95
    $ 160.00
    Professor Pinball
    $ 48.00
    $ 86.00
    Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
