Ok so I'm stumped on this one. Here's what happens and what I've done so far.
1. Coin up game
2. Press Start
3. Game goes into tilt and kicks out ball
4. Plunge ball and once it goes to the outhole the game cycles to the next ball and goes to tilt as soon as the ball is kicked out
5. Game over
What I've done so far.
Tested all tilt switches using switch edge test. All tilt switches operate properly. (slam, bob, ball roll, PF)
Ran switch status test to see if any tilt switches were active. All tested ok.
Isolated the problem to the MPU by removing the switch connectors and shorting out the trough switches to trick the game into thinking there were balls then shorted the credit button to get the game to start and it does the exact same thing with going into tilt.
This leads me to believe it's an issue on the board. I did some reading about faulty resistor packs so I ohmed out the circuit responsible for the tilt switches and everything checked out within spec.
I decided to replace the PIA at U38 thinking maybe it was kinda flaky and that had no impact.
At this point I'm stumped as the switch test looks fine.
Should I just go ahead and order new resistor packs and replace them? I hate shot gunning parts as that's not typically how I do things.
Anyone have any ideas?
