wayout440...... thank you soooooooo much for clearing that up for me. it has been lingering in my mind ever since i got the machine. Really, thank you for the confirmation.
Bobnatlanta, are you referring to the ribbon cable from the CPU to the sound board? the only other ribbon cable in the machine that i see runs from the CPU to the display board... how would i go about jumping the pins to each other? Do i use multiple wires with special connectors ? i really wouldn't want to use alligator clips (would i ? ) due to the potential for possibly shorting one out to another. Once again, i am new to this and am limited in my technical terminology for now. I may even be calling the MPU the CPU and not even realizing it. but i am referring to the largest of the boards in the machine. It has a ribbon cable that goes to the sound board. It is rather short, about 5-6 inches long in total. Is that the cable you are speaking of? If so, how would you recommend i try jumping CPU pins to Sound board pins, safely.
Thank you , you guys. I was really about to lose faith in this site and really didn't know where to turn besides sending it out for service, which i really didn't want to do. I am willing to do the work and i am not looking to be spoon fed info. Just pointing me in the right direction with some tips and i will do the rest.
thanks again. seriously.
