Hi all!
I am about to fix up my high speed that is working fairly well concidering its condition (very dusty and a lot of corosion, mainly on the coin door).
Anyway, i thought I were missing some sounds. The speech, the car engine sound, crash sound and tyres screeching. That from when i did a quick initial game to see what was not working.
Today i decided to investigate it a bit more so i went into music test and sound test from the coin door interface.
All sounds and music played from that test however, the sounds i thought i was missing played at very low volume! (they probably got drenched in the music so thats why i thought they were missing) Really different from the other sounds like the music etc.
Ive read the sounds on this machine are played from different sources, some from the sound board and some from the cpu board. So i thought that maybe there were two different controls for the sounds. I have found one to the left inside the cabinet and it affects the music etc but not the speach and "missing" sounds.
On the sound board there are no volume adjuster though it looks its possible to install one since something similar is pictured on the board in white. (See picture at the end of post)
I then proceeded with pressing the SW1 for sound test on the CPU board as described in the manual (from attract mode). The game gave off a sound that i can describe similar to a police siren, like a sine wave where it goes from high to low and back and forth.
The main question i have here is what this mean? What kind of sound should be heard from pressing this button on the CPU board?
Some more info,
When i got the game it always displayed the factory settings restored message even though there were batteries in (4,6VDC i measured) so i poked around a bit with the battery holder and it seem it is pretty dodgy, sometimes work and sometimes not. Now it keeps the settings and goes directly to attract mode when booting. BUT, the startup sound bong is now gone... it was there before!
I can also mention that pressing the CPU test button on the CPU board, for the blanking circuit, gives an "8" on the display on the board and then back to the "0" that should indicate that it boots up normal and is not malfunctioning.
So, to summarize:
1. Is it possible to get a higher volume on the speech and crash sounds, like with some adjustment?
2. What should be heard when pressing the sound test button on the CPU board? If what i hear is not normal, any ideas of what it means?
The missing sound bong might have something to do with bad connections etc. so I will try to clean all the connectors and see what happens. Allthough all sound should be gone if the speaker connectors are bad...
