(Topic ID: 254969)
High Speed Sound Completely Gone
By Andy_B
17 days ago
  • 20 posts
  • 7 Pinsiders participating
  • Latest reply 2 days ago by gutz
#1 17 days ago
I had a problem with missing speech on my High Speed which re-appeared after I had pressed on some of the chips in the sound section of the CPU. All sounds were working correctly before this.
The sounds then all worked fine for a couple of games before I noticed an unrelated issue of the kickback not working - diagnosed to a faulty Q7. I took the CPU board out to replace Q7 and also the pre-driver Q5, and then the correct pre-driver Q3 due to the schematics being wrong
After re-fitting the CPU board I have no sounds at all. At one point I could hear the music play very faintly through the speaker with the volume turned up fully in Music Test but this has now also disappeared.
I have checked previous post on similar problems but it makes for quite vague reading.
Could someone point me in the right direction with what I should be checking first?
Andy
#2 17 days ago
Quoted from Andy_B:
Can you test for negative 12 volts at U-2 pin 3. You may have a cracked header pin on 1J-17 or 3J-6.
#3 14 days ago
FInally got some time to have a look at this.
Got 15.25v at U2 pin 3 and the same at R9 which feeds to U2 pin 4.
I understand that the sounds are produced on the sound board and also the CPU but I'm struggling to understand where the bottleneck is likely to be whereby whatever component(s) has failed would kill all the sound.
#4 14 days ago
Sounds are stored ans processed in the yellow box area. When the game calls for a sound, it is selected from the green box area. Voice clips are at the top yellow arrow and digital processed sounds are on the lower yellow arrow. The voices are amplified thru 2 op amps, sound are amplified thru Q-1. Both sets of sounds come together at the very left and go thru another op amp as combined sounds and leave the board to go to the background sound board and volume pot. Then the sounds come back in from the volume pot red arrows and to the main amplifier and leave to go to the speakers.
#5 14 days ago
Since you have no sounds at all now you need to go to components that affect both speech and sounds and background sounds. This is why I had you check the -12 volts as this powers the amplifiers. Other things to look at would be the volume pot, C-2, C-3, U-1 on the CPU board. Also check for the -12 volts on the background sound board on on side of C-6.
#6 14 days ago
Thanks for that its really helpful. With the lack of speech and a few other sounds before total failure I am not suspecting speakers (which are both new in any case) or volume pot but I'll test them and work back through the schematic.
Is an oscilloscope required for full analysis of the sound circuitry?
When I press the sound test button on the CPU board I can here faint crackling through the speaker on max volume but nothing recognisable as the sounds the game makes.
#7 14 days ago
Quoted from Andy_B:
It is very helpful. Since you pulled the CPU board, you removed 1J-17 connector. The Sound board is also tied to 1J-17. You may have pulled a wire from the sound board power connector causing all the sounds to stop.
#8 14 days ago
Probably a typo, but in post 3, Andy_B got 15.25v at U2 pin 3, not -12v.
#9 14 days ago
Yeah I saw that but thought he just left out the minus sign.
#10 14 days ago
There is a cable that connects the background sound board to the CPU board, disconnect it from the CPU board. Then disconnect the other cable from the background sound board that goes to the volume pot and connect it to the CPU board where you just disconnected the other cable. Play a game to see if game sounds work. There won't any background sounds tho. But this will tell you which board is acting up.
#11 13 days ago
Quoted from GRUMPY:
Ok I'll give that a whiz.
It was a typo in the previous post. Voltage was -15.25v
#12 12 days ago
Quoted from GRUMPY:
Ok. Done that and still no sound. Just getting crackling from the speaker when sounds are played.
Is there a quick and easy way to test the amllifier chips?
#13 12 days ago
Can you post a picture of the MPU and the sound board?
#14 11 days ago
Quoted from Andy_B:
You are going to need a Oscope for this type of testing.
#15 9 days ago
Pics as requested. Let me know if you need anything closer.
I have no knowledge of using an oscilloscope although its a good time to learn
Will this be suitable?
https://www.ebay.co.uk/itm/Hantek-2-Channel-Digital-Oscilloscope-6022BE-Used-only-once-near-mint/293319587585?epid=28032583594&hash=item444b35b701:g:8zgAAOSwCOJdvzIf
#16 9 days ago
Quoted from Andy_B:
I really can't say as I have never used a PC type Oscope. I just have a 25 year old 2 channel Tektronix.
#17 4 days ago
I see your problem, you somehow mis-wired the cables when reinstalling your CPU board.
The sound board should have both of the left-hand 4-pin connectors populated, you only have the top one (J1) filled, the bottom one (J2) is empty. There should be a short cable leading from J1 on the sound board to J16 on the CPU board (top row, second in from the left).
If you look closely at your bottom picture, you can see a 4-pin connector sandwiched in the middle of a bunch of wires that's not connected to anything. My guess is this is the cable coming from J1 on the sound board.
The cable presently connected to J16 on the CPU board goes to J2 on the sound board, it should be a very long cable that goes down to the volume knob.
For reference, I have included a picture from my game.
#18 2 days ago
Quoted from ufopinball:
For reference, I have included a picture from my game.[quoted image]
Good Eye. That would definitely cause no sound. It goes to the speaker volume potentiometer.
#19 2 days ago
This is why I like seeing pictures of boards/wiring. Cannot always tell by symptoms if something is connected/disconnected, inserted wrong, etc...
#20 2 days ago
Quoted from GRUMPY:
I think the picture was taken after Grumpy had him do some testing to isolate the problem to either the mpu or the sound board in post #10.
$ 14.00
Yorktown Parts and Equip
Gweem's Mods
2,300
Cincinnati, OH
$ 29.99
$ 19.99
$ 164.99
PinballBulbs
$ 109.00
Cabinet Parts
Tilted Pinball
4,000
Toms River, NJ
