My slingshot r really weak in my high speed. I replaced the coil sleeves on both but there was no change. Runners r new. Do the coils themselves weaken? Need to b replaced?
you can compare the coil resistance vs what's listed online for that number. Also make sure the contacts are well adjusted. Could also technically be a bad transistor on the board, but it's unlikely
Check the pivot hole of the A-12664 slingshot kicker arm itself. Too much slop in that hole will cause "lost motion" which will make the kick weaker. Also, the hole in the plastic link on the slingshot plunger might be egg shaped, out of round, or cracked. That can also cause weakness in the kick.
This page was printed from https://pinside.com/pinball/forum/topic/high-speed-slingshots-weak and we tried optimising it for printing. Some page elements may have been deliberately hidden.
