ok to start from the beginning a few weeks ago I was hand balling the game to show my little ones how things work. after the ball hits the left slingshot I hear a loud pop from the back box? I immediately power down the game an after inspection I find a transistor physically blown apart? replace the transistor and try to fire the game up no action from the slings? So I immediately check the fuses. I find the fuse for the solenoids to be blown and also to be the wrong value!!!! So I then look for the source of the overcurrent. Sure enough the left coil is showing 0 ohms so bingo (should have checked it right away when I blew the transistor) So after waiting for my parts to arrive I swap out the coil and the diode (just reused the old diode) replaced the fuse with the correct value (2.5sb) and now the moment I power the game on the coil slams shut and If I let it continue will obviously blow the fuse. I checked both switches to make sure they weren't stuck closed and they are good. Did a complete visual inspection of the rest of the area with no evidence of an issue. I am really stumped here? I did forget to check and make sure my diode was ok before I reused it could that cause this issue if it has failed? Any help would be appreciated. Thanks.
