Yep, energizes as soon as you turn it on. Tested the TIP by using the MM from ground strap to the metal tab on the TIP. Yes it buzzes. But so do all the special solenoid TIPs. If I pull the J19 from the cpu board the coil does not lock and buzz goes away in testing the TIPS. If I test for ground from the row wires at the coil I get buzz to the ground strap. I took the row wire off each coil. Buzz went away when I removed it from the left upper bumper. I reconnected all others and buzz would stay gone unless I touched the row wire to the bumper coil. Thought I found the problem. Started tracing the wire back to see if I could find the short. Then noticed wiggling the connectors from pf to bb the buzz would break up. Found that if I wiggle the red and white striped wire in the white plug this seems to be what breaks the buzzing up. This is the one that runs to the other lug on each coil. Strangely now removing and disconnecting the row wire from that pop as no affect on the buzzing while the meter is touching the ground strap and the TIP. Anyway I got it to quit buzzing by fiddling with that plug. But if I take the lead off the TIP and touch the ground strap as well to confirm meter buzz then put it back to TIP metal tab it buzzes again... until I get the buzzing to stop at the plug. Rinse and repeat.
