Hey folks, happy just-after-turkey day!
Running into an issue post-surgery on my High Speed MPU. Background: Transistor Q73 burned itself up (thing looked like a roasted marshmallow), so after pulling the MPU I determined Q72 and Q73 dead. The resistors R105, R106, & R107 were also not measuring correctly (when compared to the others for these similar transistors). So I replaced the transistors & resistors. My replacement resistors are series chains of 2-3 resistors to create the appropriate resistance. After I installed these too, everything looks good except for R106.
R106 should be 560 ohms. Before I installed my new ones, I verified it was good (I put together a 330 & a 220 so it measured about 550). After I installed it, however, it's only reading about 47 Ohms. I removed it again, thinking I'd screwed it up somehow, but then after removal I measured it again and it still reads 550. What's happening here? If the other similar resistors (e.g., R109, R103, etc) were doing this too, I wouldn't be concerned, but they're not. Why is it dropping so much, and what do I need to do to fix this?
