Greetings! New High Speed owner.
We unfortunately had to remove the Head in order to get the machine down to my basement. Everything went swimmingly, EXCEPT in the process of getting everything set, the yellow wires soldered on the lower right corner of the Power Board snapped off. They were just severely weakened stranded wire. I have no issues resoldering them, I just wanted to verify the proper order of the wires.
The drawing in the manual makes it look like that pins 1->4 of connector 40 go: upper-left, lower left, lower right, upper right onto that corner of the power board. is that correct? Can someone with this pin give it a quick inspection to verify? I took tons of photos prior to the disassembly/reassembly, but unfortunately none of them clearly show the wire order.
Another schematic later on in the manual seems to indicate that this area of the Power Board is for "General Illumination". Based on that, I should be able to temporarily leave those wire off just to test the general function of the game (to verify proper reassembly), correct?
Cheers.
-- M
