Well, I tested the F2 fuse and it tested good. Upon closer visual the F4 fuse right above it looked sketchy. So, I pulled that one and it tested bad. The paper that is still affixed above the power supply indicates the F2 is linked to a solenoid and the F4 is linked to a "special solenoid".
When I compared both fuses the good F2 fuse is a Bussmann MSL-5 250V. The bad F4 fuse is a unknown brand (it does have a FL or LF marking on the end) 313 2.5A 250V. They look similar in construction. The reason I bring this up, is when I go searching for replacement fuses tomorrow, is there a certain model/brand fuse that is a common replacement for either one of these.
The manual says they both should be a 2.5A 250V slow blow fuse.
I really do appreciate the help.
d1
