Recently picked up a high speed pinball in trade.
My issue is that all the flippers work except the bottom right one near the apron.
the upper right and bottom left work perfect above it but it is as if the bottom right does not move at all when you push the cab button.
I have cleaned the eos switches and the coils look relatively good as does the fuse.
any suggestions to getting this bottom right one back up and running? nothing seems binded and it moves freely by hand spring seems newer.
It looks like the upper right may give a signal or power to the lower right flipper and the disconnect between it working may lay somewhere in there.
