Just picked this up and I'm diagnosing the first run of issues.
The Speeder 2 and 4 displays don't seem to work no matter what I do. Speeder 2 has come loose from the top where it should be stuck down but the pins all still look good. That said, I had a similar issue with my Af-Tor and had to resolder a break. Wouldn't be surprised if that happened here. Not sure what's up with the Speeder 4 display since everything looks fine there. I tried swapping cables and that didn't fix anything, so I think the cables themselves are okay.
The other main issue I'm seeing is that it seemingly won't save settings no matter what I do. I've tried several different sets of batteries, although I haven't actually measured the output voltage from the pack to make sure it's getting what it needs. Refresh my memory on where the probes need placed for that?
Otherwise this seems like a pretty decent example, save for the typical playfield yuckiness. The cab and the glass are both pretty nice IMO. Looking more and more like a prime hardtop candidate. It plays fairly okay except the left pop bumper isn't registering all the way around the skirt (spoon or switch adjustment will probably make it better until a full rebuild happens) and I can't seem to make the ramp shot from the upper right flipper, so maybe a rebuild needed there, I'm not sure.
All in all, can't complain for what I spent. After I fix what needs fixed I should be in this for about what pinside says it's "worth" but it should be A REALLY nice example. Or at least I think so!
IMG_20190902_101546 (resized).jpgIMG_20190902_101436 (resized).jpgIMG_20190902_101448 (resized).jpgIMG_20190902_101508 (resized).jpgIMG_20190902_101528 (resized).jpgIMG_20190902_101535 (resized).jpg
