(Topic ID: 233964)
high speed issues
By fluxgold
2 years ago
  • 16 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by fluxgold
#1 2 years ago
hi,
i just got my new high speed. if i do the soundcheck then not all sounds are played .... the music is working good. but if if counts all sounds up in "sound test" service menu then some numbers are not playing any sounds. not playing:  00, 02, 04  06, 07
CPU Chip is getting very hot on audio Board.... normal ?
and when i start the game and shoot the ball in the play field then it always goes right of the ramp... could it a bad metal lane at the shooter lane ? it just don't hit the ramp from there....
thanks for your help
greets
#2 2 years ago
Quoted from fluxgold:
I'm sure others with more knowledge than me can help you with the sound issues.... But, if the ball when shot is not hitting the ramp, if you look under the plastic on the right side where the ball exits the shooter lane you will see that you can adjust the angle that the ball comes out.
#3 2 years ago
hi freeplay40 - that ramp problem i have still fixed - thanks ... but still need help with that sound problem
#4 2 years ago
From the manual it says, "The BALL IN PLAY/MATCH display shows a series of test steps from 00 through 07. Verify that a different sound is heard each time the number in the BALL IN PLAY/MATCH display changes."
#5 2 years ago
i replaced the sound board with a new one that should work but still the same problem....
1 month later
#6 2 years ago
Hi,
well i still hear no fx Sounds. I checked and also changed U24 CPU - OK , I checked and also changed U9 PIA - OK , i changed RAM U23
i first changed PIA , checked , no sounds, then i changed CPU, no sounds then i changed Ram U23 - no sounds
week ago status "not playing: 00, 02, 04 06, 07"
now all sounds are not playing .... just music from external soundboard.....
i have changed all roms
i have not changed the amplifier U1 and the D/A converter at U2
if amplifier would be broken then i would hear the sounds when i turn up the volume - but i really hear nothing .
can please someone help me ?
#7 2 years ago
no ideas ? i have no oscilloscope...
#8 2 years ago
You could have two of the 4 pin connectors wrong. If so, the game will play no sounds.
I only know this because I have done it before. Also, after owning 4 High Speed machines, I have learned from others that it's a common mistake when testing,swaping or just pulling boards to work on them.
Double check pic here: see how the lower 4 pin connector is the gray shielded cable. If you switched them, you will get no sound.
#9 2 years ago
can you please mark it ? i dont know what cable u mean
#10 2 years ago
would be awesome help i hope you dont mean the external cable from sound board
#11 2 years ago
These two connectors are both four pins. Easy to connect wrong...
#12 2 years ago
well that are on external sound board - i have the music from that
#13 2 years ago
I don’t understand what you are saying. You posted before there is no sound now.
#14 2 years ago
i hear no fx sounds and speech.... but i hear the music
#15 2 years ago
I know you said you don't have a scope but you can still check these steps off to confirm voltages and rectification. If you hear music, your amp and everything after the boards are good! :
#16 2 years ago
thanks i will check this
