Hi everyone. Had a new issue arise on my HS2 last night. The right flipper was making the game reset. when pushed, the bottom right flipper would work but not the top right flipper.normally within one or 2 pushes it would reset. Had no such issue with the left.
I checked the wiring to each coil and switch and all looked in order. I gave all fuses the eye test & meter checked any which looked suss, as well as all the fuses on the fliptronic board. I then re-seated the connectors fr J101, J102, J103 & J104. After re-seating, the game is resetting instantly on either flipper.
Is this likely a pin/solder issue on the J101? Any other clues?
