The machine appears to have been sitting in a damp place for a long time and there looks to be some battery acid damage but I've never really seen it in person. The game boots up, notices there is no stored settings, I can set the settings to factory (although the display output is missing some parts of the letters) and then it lights up like it is waiting for coins. Hitting the start button makes the "vroom" sound and then nothing changes. The CPU board letter is "0" and then I hit the CPU button and it goes to "E".
Unless someone replaced the battery holder (which means you would think it worked at that point) I don't see any damage on it.
I assume the traces are messed up somewhere but maybe this is worse? I am going to pull the board and check out the back side but I was hoping for a bit of direction as to where to go before I do that. Any other things to look at, tests to do, etc? Fuses look intact.
I can post a pic of the back side if I should pull it as a next step. I saw someone on ebay selling a repair service for the high speed version so $300 it seems or refurb boards for $500. Not sure what a damaged version is worth, assuming this is the issue and someone can fix it.
