I decided to rebuild the flippers on my High Speed project. I wanted to change out the conical spring to the newer WPC style. The first coil I did I put the sleeve in the way the new games are. The bracket that holds the coil in place opposite of the stop didn't have the notch to mount it correctly. I ruined the coil trying to get the sleeve out again. The coil was toast anyway if it didn't come out easily. No big deal. Now I need a new coil. I see some people putting in the 11630 instead. I have a few of these on hand. I do not have the 23-600. My bracket also has the short EOS mount, not tall enough to drill for the return spring.
Should I just buy the proper bracket with the tall EOS bracket or is there an easy mod?
Should I replace the 23-600 with an original coil ir go with the newer 23=600?
