My high speed has blown the q43 twice in the last 3-4 weeks. I was testing for shorts last night on that column wire to see if GI or other high power was getting into the line and noticed that the EOS, when tested, shows continuity whether opened or closed, on all three flippers. None of my other system 11 games do this, they all break continuity when opened as they should. I would assume that something is wrong and that the high speed's EOS switch when being tested should break continuity when opened, correct? High Speed remember has the old 1 diode coil unlike newer 2 diode flipper coils on newer games. Any thoughts?
