We are at a campground where there's a High Speed so I'm trying to be the hero & fix it with your help.
When I put in a quarter or 2... the credits show but when the credit button is pressed.. there is nothing like no coins were put in. Any ideas?
So you coin in, get your credits, then you push start and the (all? or just one?)credits go away, but no game starts?
My reflex answer is that it sounds like a cabinet tilt switch is stuck.
However more information as to what is happening would help.
For example:
Does it try to put a ball in the shooter lane?
Any solenoids going off?
Any sounds?
Game over or tilt lights blinking?
Thanks for the replies.
After puting coin/coins in... there's the usual sounds & credits show... I press the credit button then no ball trying kick up..credits go away.. just goes to nothing
Quoted from scampcamp:Thanks for the replies.
That's a money maker!
I LIED !
Actually... After inserting a coin there is the usual sound but NO credit shows & it says Game Over even after puting coin in.
So coins are not putting credits on.
Sounds like the coins are not hitting the credit switch or some problem with the credit switch.
There are sounds like a credit is up but no ball kicks out. . there is no light on the point displays either. If I kick the ball up thru manually... the flippers sometimes work & some of the targets make noise but still no lights for points displays.
Thanks again for your replies.
Try this thread, maybe you'll get an inspiration on where to look if you ask mof.
https://pinside.com/pinball/forum/topic/high-speed-restoration
Thanks! I looked for a slam tilt switch on the inside of the front door & couldn't find it. Would it be in a hidden spot?
Number 20 on the right page.
http://www.planetarypinball.com/reference/partsmanuals/WMS_Parts_Blue_16-9064-B/index.html#/646/
or maybe # 18 on this left page but either one is in about the same spot.
http://www.planetarypinball.com/reference/partsmanuals/WMS_Parts_Blue_16-9064-B/index.html#/628/
but in general you are looking for a switch that has a small round weight on it,
like the bottom right of the left page here.
http://www.planetarypinball.com/reference/partsmanuals/WMS_Parts_Blue_16-9064-B/index.html#/94/
Could be on the back of the coin door, in the cabinet floor or side, under the playfield, maybe even one in the backbox, check for all of them I'm not sure how many tilts or where exactly they are on HS.
Not sure but a closed slam tilt puts the pin into "game over" mode.
Check out page 4 of the manual. See if your pin is in Attract mode or Game over mode or what. Knowing what state the game is in helps with trouble shooting.
For example here is what is says under game over mode:
"GAME OVER MODE. The GAME OVER indicator lights. The SPEEDER 1 and SPEEDER 2 displays show GAME OVER. Then, the high scores flash on the appropriate player score displays. The game proceeds to the ATTRACT MODE."
So if the switch is stuck closed the game might stay in game over mode and never get back to attract mode.
This is all just guess work on my end. How did the switch levels test pg (25) go?
Link to manual if you don't have: http://www.planetarypinball.com/reference/gamemanuals/High_Speed/index.html#/4/
This page was printed from https://pinside.com/pinball/forum/topic/high-speed-credits-w-coins-then-nothing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
