(Topic ID: 76524)
High Speed Coin Door & Switch, Will it Work on The Getaway?
By pinrock
5 years ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by pinrock
#1 5 years ago
Is the High Speed Pinball standard coindoor similar to newer coindoors like on The Getaway...specifically is the test switch configured and wired the same and can I use it on The Getaway?
Thanks in advance for your help!
#2 5 years ago
Getaway uses 4 services switch and as far as I know High Speed uses only 3 - so there is a difference right away that would not make it a simple plug and play (even if it was you would lose some functionality).
Also the connectors are did (I think) - the Getaway uses a flat Molex connector that plugs into a board near the coin door vs. High Speed probably feeds back to the main board in the back box.
If they both used the same system processor, then yes, but since they don't - not likely without changing the connectors (and still missing a service button).
#3 5 years ago
Quoted from LongJohns:
Thanks for the info, I appreciate it!
€ 95.00
FlipperLED
$ 14.99
PinballElectronics.com
