(Topic ID: 247299)
High Speed coin door buttons not working.
By Andy_B
4 months ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 14 days ago by Andy_B
#1 4 months ago
Hi.
I had a fully working but very dirty High Speed until I removed the playfield to clean it. On re-fitting I have a clean High Speed but no longer fully working
I can't get into audits or adjustments with the coin door buttons. If I press the Advance button the pin goes straight into MUSIC TEST and I can't advance out of it. I have to switch the machine off. The buttons were working fine before.
The ADVANCE and AUTO UP/MANUAL DOWN buttons connect to U14 which I  swapped but no change. I also swapped U56 but misread the poor quality copy schematic and should have swapped U36 which is connected to the MEMORY PROTECT switch. Surprisingly swapping U56 didn't change anything
I have checked U36 (7404) pins 10 and 11 (MEMORY PROTECT) with the logic probe and it seems to be giving the correct output for a given input, which changes when the switch is pressed as expected.
I can start and play a game OK otherwise.
The only other IC in play is PIA U51. Any suggestions before I pull the trigger on this chip?
Andy
#2 4 months ago
Use a logic probe to ensure the signal is being propagated properly.
Have you tested the switch?
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact
#3 4 months ago
Finally enlisted the help of my daughter as I couldn't reach U14 with the logic probe as well as press the coin door buttons.
As soon as I started testing the buttons they started working again, without me doing anything. They continued to work after several power cycles. The next day I was again only able to get MUSIC TEST.
I think it may be an issue with the AUTO UP/MANUAL DOWN button as if its a logic failure I doubt it would be intermittent.
3 months later
#4 14 days ago
Just realised I haven't finalised this post. I had a loose wire on the diagnostic buttons that must have been making intermittent contact.
It finally broke off the other day. Resoldered and all good.
2,300
Cincinnati, OH
4,000
Toms River, NJ
$ 14.00
Yorktown Parts and Equip
PinWoofer
$ 19.99
$ 99.00
Pinball Sales
$ 164.99
PinballBulbs
Gweem's Mods
