I have been cleaning, working on, and collecting parts for further work on my first pin for a few weeks now. One problem I've run into is that I manged to break a previously-working switch, one of the two in the right hideout. Marco has the part listed, but naturally it's out of stock: http://www.marcospecialties.com/pinball-parts/A-11047
The switch itself works fine, but the plastic housing that holds the wire portion contacted by the ball is broken. The wire portion is supposed to be supported on both sides by plastic and pivot up/down when the ball hits it. Because one side broke, the metal piece won't stay in place (see attached photos). Any thoughts on how to fix/replace it? I've looked at a few other pin parts sites and no one seems to have this exact switch for sale. I don't care if it's replaced with a perfect match, as long as it works, but I don't know what might be a suitable replacement in this case. I've worked on vids since 2001, but I'm new to pins and I'm not sure if I can just drop any old cherry switch into this position or not.
