I could use help puzzling this out. Blowing 5A fuses (general illumination string) on startup.
-All lamps are removed from the (right playfield)
-With 3J8/GI power supply connector connected, I get continuity across the fuse holder WITHOUT a fuse so something is very wrong
-With 3J8 unplugged problem fuse holder has no continuity
What should my next steps be?
How can I narrow down where a short in the string could be? There’s just continuity everywhere in the string so that doesn’t help.
I’ve visually inspected lamps and sockets but can’t see anything amiss but I’ve done tons of work (Not to GI directly) so I messed up something...
