Now for an issue I was dreading... the infamous Taxi shooter lane. This is a critical part of the game and has to work perfectly.
After adjusting the shooter rod housing, the tip is perfectly centered hitting the ball. I shoot the first ball on this game and get a clunking mess that only yields around 4 revolutions in the spinout bowl. Ugggh, not what I wanted to see!
There are 2 important transitions- the beginning of the shooter lane to the wireform and the wireform to the entry lane of the spinout.
I found that the best tool for getting these transitions correctly lined up was the Slo-mo video feature on my phone. I filmed shooter lane shots over and over, looking for any places where the ball was losing momentum.
First transition looked good. Entry to the wireform is sitting correctly in the grooves, just slightly above playfield level. Ball is going straight into the wireform without hitting the sides.
Moving to the other end of the wireform I saw that as the ball exited the wireform, it was just catching the left side of the entry lane to the spinout bowl, bouncing the ball off the walls of the entry lane and slowing it down. As you can see here, it's a little off to the left:
I adjusted the wireform to get a straight shot directly to the spinout bowl.
