My procedure was pretty much the same as HS decals. I did the front first. The door and start button were already cut out, so I figured that was again the best place to start since I would need to line up the sides with it and I wasn’t going to have much flexibility in the placement.
I went ahead and installed the start button so I would have an accurate way to center the decal.
I again used the hinge method to install them:
1. Line up the decal and put a heavy object on one end of it.
2. Lift the opposite end and remove the backing paper to expose the adhesive, about 25% of the entire decal.
3. Cut the backing paper off with scissors and let that end of the decal adhere to the cab. I still used my felt-covered squeegee to smooth it out, but honestly, with these you could just do it with your hand.
4. Remove the heavy weight and place it on the finished end. Lift the unfinished side and pull the rest of the backing paper as you smooth out the Radcal until it’s finished.
That’s really about it for the installation. The sides are obviously much bigger than the front, but the process is the same.
