Read the example they gave you at the bottom of the card. Each color wire gives a 10k point range. By plugging that wire into the appropriate hole you can increase that base number by the hole it's in.
If you want 47,000 for a replay score find the wire listed on the chart. In this case it's white as it's between 41,000 and 50,000. To make it 47,000 put it in the 7,000 hole. If you want 50,000 put it in the 0000 hole. If you want 41,000 put it in the 1,000 hole.
A replay is a free game. This is not a high score adjustment but rather a replay threshold. When you surpass this score you get a credit for a free game. It actually increments the credit wheel one number.
Quoted from schudel5:Read the example they gave you at the bottom of the card. Each color wire gives a 10k point range. By plugging that wire into the appropriate hole you can increase that base number by the hole it's in.
My Wizard is set up exactly that way, however the card says replay at 65,000 - 95,000 - 115,000. How can I set it that way when there's only 1 5000 spot?
image (resized).jpgWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/high-score-adjustment and we tried optimising it for printing. Some page elements may have been deliberately hidden.
