Hello I have a high hand that is stuck in tilt after it kicks out the ball, ive tested the various tilt switchs (backbox, under playfield, plumbob, the one on the left side with the rail with the ball in it) with my DMM and they all say there closed when there clearly not, the ball count unit doesnt move up to ball one after it gets kicked into the shooter lane. Also theres a wire i dont know where it goes in the backbox, I thought it went to the jones plug closest to it on the bottom left connector seeing as that's the closest part that it couldve gone, and the wire that is connected there is the same color. I have schematics, any help would be much appreciated.
After some further testing, im not so sure its stuck in tilt, actually im not sure what to think about it anymore, this is a first EM game for me so there will be mistakes, but the tilt light is constantly on and the tilt switchs are all showing closed so i figure'd it was stuck in tilt. I was able to get the playfield lights on by actuating the Hold relay (R) manually which turns off the tilt light, other then that i've made sure the score reels are runing freely, one was gumed up so i cleaned it and they all run smoothly now. Not sure what to make of it but time to go read up more on EM repair, its been fun working on it and i find EM's much more fascinating than the newer solid state machines.
