On my Harlem, i realized the two lower spot targets in the left five-bank weren't registering. In self-test, no switches were coming up as errors. I took a look and saw some truly weird wiring.
As you can (kind of) see in the pic, the two white/yellow wires from the harness are soldered onto the SECOND target's side lug. then another white/yellow jumps from that lug to the first target's side lug, and another white/yellow then leapfrogs from the first target's side lug up to the THIRD target's side lug. This color wire then goes sequentially from side lug to side lug, 3-4-5, all of which are registering properly.
I assume I need to move the incoming two white/yellow wires to the first target's side lug, and then make the 1-to-3 wire go 2-to-3 - can anyone confirm?
